20 Most Recent HP Compaq dc5750 Small Form Factor - Free Flat Panel until 113007 EW318AV-KAM PC Desktop Questions & Answers
3answers
How to Remove Smart card Authentication Error on HP dc5750
i have the same problem , if u did find a solution just tell me
9/27/2018 6:09:59 PM • HP Compaq dc5750... • Answered on Sep 27, 2018
How to remove smart card authentication problem
Deinstall that program from control panel-> programs and features
4/1/2016 7:11:17 PM • HP Compaq dc5750... • Answered on Apr 01, 2016
Hp 5750 powerup password
removing the battery would not solve the problem
You would have to find a jumper Green in color near the CMOS Battery area,It would read PSWD on the motherboard
It will be connected to pin 1 & 2, change it to pin 2 & 3 - this will reset the password,
Now clear the CMOS by pressing the power button
Then restore the jumper back.
Thanks
Proton
9/2/2010 1:44:08 AM • HP Compaq dc5750... • Answered on Sep 02, 2010
2answers
Unknown power-on password on hp dc5750 desktop
Sounds like somone has put What they call a bios/boot user password this is a password thatis used before windows even loads up.
If no one will tell you the password the only other way i know of to reset the password is to open the computer case and remove the CMOS battery which is a CM2032 button batter you cant miss it
Remove that battery and remove power to the case for a few minutes then replace the battery and power back on.
1/30/2009 6:21:10 AM • HP Compaq dc5750... • Answered on Jan 30, 2009
0answers
Dc7900 video problems
  • Then DOWNLOAD install video driver.(Graphic Driver)
When you restart your pc the problem will be solved!.
1/4/2014 4:42:14 PM • HP dc Computers... • Answered on Jan 04, 2014
Mico code update error how ifix that
do you mean microcode for BIOS.clear cmos.
4/5/2013 4:55:55 AM • HP dc Computers... • Answered on Apr 05, 2013
Do you need a cpu heatsink fan on a compaq dc5700 desktop pc
Didn't it come with one?
3/20/2013 12:20:09 PM • HP dc Computers... • Answered on Mar 20, 2013
Xw6400workstation hp changed motherboard still4bleeps pc wont start
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in. Open computer and reseat memory Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST, disconnect the riser board(if applicable) and each of theexpansion cards. If this resolves the issue or allows the computer to POST connect one card at a time until you determine what card is causing the issue. Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect theIDE, SATA, SCSI, or other data cables from theCD-ROM, Hard Drive, and floppy drive from theMotherboard. If this resolves your irregular POST or generates error messages re-connect each device until you determine what device or cable is causing the issue. In some situations it can also be a loose cable connection that causes the issue. Remove the RAM If you continue to to receive the same problem with all the above hardware removed, disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. ' Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue. Re-insert the memory into the same slot. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick. Try one stick of memory in each slot. If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify what stick of memory is bad and replace it. If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard. Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot. This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware. Disconnect and reconnect the CPU (central processing unit) For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer. Bad motherboard, CPU, RAM, or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have badMotherboard , PSU ( power supply unit ), CPU, or RAM. The next step would be either to replace these components or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order or try swappable parts from other computers.
2/21/2013 2:29:36 PM • HP dc Computers... • Answered on Feb 21, 2013
0answers
0answers
Download driver audio hp AD0912US
You can download the audio and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: - http://welcome.hp.com/country/au/en/cs/support.html
9/17/2012 7:23:47 AM • HP dc Computers... • Answered on Sep 17, 2012
Hp dc5700 micro tower using winxp wont boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease
hope this helps
6/5/2012 3:56:52 AM • HP dc Computers... • Answered on Jun 05, 2012
HP Compaq dc5750 Small Form Factor - Free Flat Panel until 113007 EW318AV-KAM PC Desktop Logo
Popular Tags
11 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
dc HP
  • dc HP
Most Popular Question
remove smart card authentication error
  • Computers & Internet
