20 Most Recent
Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A Questions & Answers
Can I replace insulation in door only?
Hi - I understand that you recently had something heavy drop on top of your Frigidaire Freezer door. From my experience the condensation does typically indicate poor door seal. When cold air and warm air outside is entering into the freezer it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit. Hope this helps! JK
Chest freezer model mfco5mobw4 been plugg in for 2
God day,
Either the refrigerant has leaked out or the compressor isn't pumping properly. If you can put your ear up to the unit and it hums that is the compressor running.
No practical repair possible unless the unit is under 5 years of age in which case you are entitled to factory warranty service.
5MONTH CHESTFREEZER WHICH WAS WORKING .PUT IT IN
I am having this problem also with my freezer not freezin after been unplugged for about 3 months, is it just stuck in refrost mode and if so what do I do? I has been plugged back up for the past 5 days and nothing but a hot freezer...yuck
Just got a used 5.0 frigidaire chest freezer and
Good day,
The interior walls should frost evenly. If you only get a partial frosting pattern then either you have a refrigerant leak or a restriction in the refrigerant lines.
Either problem would be considered a terminal failure in a chest freezer.
Stopped running
First check to make sure you have 120 volts to the unit. If you have power to the unit you then need to check the temperature control to see if it works(closes) and gives 120 volts to the compressor. Does the compressor make any noise like it is running and does the compressor get warm or very hot. Try this first.
After being unplugged for one year, my Frigidaire
It's probable that you've lost refrigerant in the cooling system. Unfortunately, leaks in those systems can be hard to find so check your warranty to see if the labor is still covered.
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Frigidaire cf-5f-lx2 1989 modle
Greetings!
Since the overload was good when tested, check also the electric current if the current is in the right voltage.
If the problem still a raise, it is now the motor compressor that have problem. The motor it self cannot start or hard starting.
Thanks.
