20 Most Recent HP Thin Client - AMD Geode NX 1GHz - 256MB DDR SDRAM - 512MB Flash - Windows XP Embedded - Tower HP Com... Network Terminal Questions & Answers
I got this error while installing it through over
Hello Gomatesh_b, I've read a article on it just a month before, i think, it will also help you. There toll-free number was +1 (844) 355-5111.
9/13/2017 9:58:49 AM • HP Thin Client -... • Answered on Sep 13, 2017
How do I check ink level in my HP Photosmart C4200 printer?
If your HP is installed you have "HP digital imaging monitor" on your toolbar.
1. right click, you will see "HP Photosmart..." - "Display status"
2. Click "View Ink Levels"
7/23/2011 12:23:56 PM • HP Thin Client -... • Answered on Jul 23, 2011
I can't find the ink level on my 4200 hp since i
The issue is with the driver you are using for the 4200- I suspect if you visit support.hp.com, you would find the utility for windows 7 that would have the same function as in windows XP I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
1/21/2011 1:19:33 AM • HP Thin Client -... • Answered on Jan 21, 2011
How do I check the ink levels on my HP Photosmart
Start the "HP Printing Assistant" software, and click "Utilities", and then click "Ink Levels".
9/26/2010 11:07:52 PM • HP Thin Client -... • Answered on Sep 26, 2010
Change ink tank
Dear client ,
form the only words you posted I assume you are talking about a printer ..but you did not explained what kinda model and make..and you posted in the wrong section ...
Please inform about the model and problem ..in a comment ..
9/16/2010 2:32:52 AM • HP Thin Client -... • Answered on Sep 16, 2010
How do I check ink levels on my HP C4280?
HP provides a great tutorial on how to check the ink levels for your specific printer, I would reccomend installing the drivers they list in the first method as this will provide you a better experience with your device overall.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00257147&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=sg&product=3192753&lang=en
If you have any questions, please let me know!
Thanks,
Mike
5/16/2010 8:09:42 PM • HP Thin Client -... • Answered on May 16, 2010
HP LaserJet P4014n is leaving vertical spots on
i think you need the jets cleaned my freind but i fix comuters not printers i only replyed as i have an epson that happend too and i got the shop to clean the heads/jets on mine and it was fine hope this is of some help
3/17/2010 10:21:40 PM • HP Thin Client -... • Answered on Mar 17, 2010
How do i fin d out how much ink is left in the ink
Install the software from the CD-ROM that came with the printer.
One of the "tools" in that software can be used to query the ink-levels in each cartridge.
1/23/2010 12:45:12 AM • HP Thin Client -... • Answered on Jan 23, 2010
Just installed HP p6240f desktop with Windows7.
First, I thought your assistance center would respond to my request since this same problem appears in the HOP website problems & solutions.
I did not resolve the problem after downloading the All In One Series software. It failed to complete the installation after hours of loading.
I did my own tasking and found that I could resolve my oproblem by Control Panel - Devices (printers) - HP 7130 Officejet-Scan Document.
It worked.
Savuing the scanned document is quite different in this Windows7 setup from the prior XP. It is more circuitous to get to where I want to place the file.
12/7/2009 6:25:10 PM • HP Thin Client -... • Answered on Dec 07, 2009
How do I find a user manual for a
Not a manual per se, but yhou can view/download just about everything pertaining to your computer here:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_task=useCategory&lc=en&dlc=en&cc=uk&lang=en&product=4041179
11/28/2009 4:42:00 AM • HP Thin Client -... • Answered on Nov 28, 2009
2answers
Change operating system
You can keep both Vista and XP. Below is the way to install XP, after Vista was already installed... creating a dual boot. First find the drivers for your network components, wireless card or nic, and save them to an external device such as a floppy disk or flash drive. Then you will need to go into the BIOS on your computer startup. Scroll to the System Configuration tab and go down to the SATA Native Support and change its setting to Disabled. Then hit F10 to Save and Exit. Next, insert your Windows XP CD and create the partition you wish to install XP on. After the installation is complete you should boot automatically into XP. Now you need to move some files. First, make sure you have set your folder options to see hidden files and to show protected operating system files. Then open Windows Explorer and go to the drive where Vista is installed. Copy the folder Boot, and the files bootmgr, boot.ini, NTDETECT.COM and ntldr and paste them to the root of your XP drive. Then download Vista Boot Pro and save it to your desktop or somewhere else that you can easily access. Unless you already have .Net Framework (v2.0 at least) it will redirect you to a Microsoft page where you can download this necessary component. Install and run Vista Boot Pro and open the "Bootloader" tab. Select "Reinstall the Vista bootloader" and press Apply. Then go to the Manage OS Entries tab and select "Add new operating system entry" and make sure you select "Windows Legacy". Give the new entry a name (ie: Windows XP) and select the drive letter you have XP on and then select Apply. You can also choose which entry you would like as the default the system will boot to. And now you should be able to dual boot between Vista and a previous OS. Thank you! Sabharish
6/15/2009 5:47:38 PM • HP Thin Client -... • Answered on Jun 15, 2009
Com surrogate has stopped working
http://fileforum.betanews.com/detail/Vista-Codec-Package/1159994557/1
Just download this small program and everything should be just fine . I was having the same problem , ive been told that its because of nero or divx codecs , didnt unistalled anything just installed this program and my problem was solve !
5/3/2009 8:42:17 AM • HP Thin Client -... • Answered on May 03, 2009
WEBCOM & Wi-Fi do not working
hello sir my laptop is compaq model no v3424au my laptop prblm is just start on white display... nd hang on white display..nd my laptop is not proper working... pls help me. i check my laptop near service cente...but i will not proper satisfied. This prblm is allready my laptop here.
3/19/2009 6:13:03 PM • HP Thin Client -... • Answered on Mar 19, 2009
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered on Apr 17, 2024
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
HP Thin Client - AMD Geode NX 1GHz - 256MB DDR SDRAM - 512MB Flash - Windows XP Embedded - Tower HP Com... Network Terminal Logo
21 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
change operating system
  • Computers & Internet
