20 Most Recent Dell 1201MP Projector Questions & Answers
If you projector can not process SVGA then no there is nothing you can do
Dell 1201MP... | Answered on Dec 16, 2015
Have you opted to switch display to the printer using the function key with either F4 or F5, you will see the laptop symbol with a square next to it.
I think option 2 showing two screens with no 1 in them works best with Toshiba.
If you try this and fail, you can look at the From your desktop, Proerties, Settings, Display - Option Plug and Play!
Let me know how you get on with the above.
Dell 1201MP... | Answered on Oct 16, 2012
hi,
You can use the VGA input for connecting the PS3. for that you need D-sub to HDTV/Component cable. Connect the vga sid to the projector and the component RCA side to your PS3. Your PS3 have the component video out.
ok
Dell 1201MP... | Answered on Aug 08, 2011
you have most likely lost 2 of your color guns, most projectors have RED, Green and BLUE as the projector colors (some newer projectors have added a 4th color). if one of your color guns has gone out, you may experience colors that are not correct. that is where I would start. go to the convergence routine, in your setup menu. this is where you can determine if one of your "guns" has quit working.
Dell 1201MP... | Answered on Mar 23, 2011
Ring DELL service and tell them your problem and they will tell you how to fix it
Dell 1201MP... | Answered on Mar 19, 2011
if it was merely a power surge then the fuse may only need changing.
If it was a lightning strike, then the Switched mode power supply may have been damaged as well.
Either way only an experienced technician should attempt to work inside as there are lethal high voltages present.
Dell 1201MP... | Answered on Mar 01, 2011
Dell 1201MP Projector Logo
53 questions posted
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
dell 1201mp projector screen flickering
  • Office Equipment & Supplies
