20 Most Recent
SIM2 Grand Cinema HT305E Projector Questions & Answers
Picture is very unclear then
The projector could be getting too hot and is therefore freezing. Make sure that there is significant airflow in and around the projector. I suggest cleaning out any dust that may be clogging its vents.
How do i change the focus without the remote?
There ia always a ring around the lens of all optical devices. If you power on the projector and rotate this ring clock or anti clock wise then you will find that you are able to focus the device to the best of display. Else try the settings manually if there is a provision.
How to reset lamp hours on Sim 2 Domino 18
I am not familiar with your brand in particular but they are all pretty much the same. In the menu under settings you should be able to scroll to lamp settings. Under that category or something like that will be where you can reset the hours.
Power fuse keeps blowing, as
There is most likely a short circuit in the power supply unit, or on the main processor board.
You would have to disconnect the cables running from the power supply to the other boards and gradually reconnect them until the problem shows up again. If you have the service manual you could follow the fault finding procedure, but would need to have a lot of experience in electronic fault finding and the correct test instruments.
How do these points equate to money?
No money ever!
There is no payment made for answers on Fixya, points don't mean prizes, they are just for fun.
ADMIN Andrew
- Answers: 65,820 and not a penny per Answer.
Head over to
www.justanswer.com they pay lots of money because they charge for people to ask a question.
