20 Most Recent
Panasonic PT-D4000U Projector Questions & Answers
How do you reset lamp hours back to zero on a
When you remove one of the lamps, you're notice that there's a micro-chip build into the housing itself. Unfortunately there's no way of manually resetting the lamp hours, due to the chip. You'll need to replace the whole lamp assembly.
5/3/2011 11:00:41 PM •
Panasonic...
Answered
on May 03, 2011
Color Wheel
I'm pretty sure if the color wheel spins with no vibration that it's not the colorwheel. I would have to say that your cable is bad. If it has been bent repeatedly near the connection that the wires could be breaking down. Try a brand new cable.
5/6/2010 7:29:38 AM •
Panasonic...
Answered
on May 06, 2010
Panasonic KX-MB2025 Toner Low Problem???
Does the machine say replace drum or toner. Two different units. If toner did refill or install a new toner. There is a chip on most drums and toner to tell the machine they are new. if you refill the toner the chip is still going to tell the machine it is used.
