20 Most Recent
Optoma EP771 DLP Projector Questions & Answers
The background projects as yellow
It sounds like one of the polarisers has failed, on experience they cost £300 each to replace, and there are 3 of them. I recently bought an NEC NP115 for just over £200, very good spec for the cost. It maybe worth investing in a new one.
Hope I was helpful for you.
My optoma ep771 projector, which
By what you have told me, the lamp possibly may have blown, so check if the product is still under warranty as you may be able to claim another lamp at no cost what-so-ever!
It is however a definite code to tell you something is wrong!
Hope this helps ;)
ZKhan
Optoma ep771 displays the word menu
1) Verify the settings on your notebook or desktop PC.
2)Turn off all the equipment and turn the equipment in order.
3) Check whether the power cable is connected securely
4) Check for the Green color in the projector
5) Try resetting the lamp connections.
6) Try to replace the lamp module.
7) If you have replaced a lamp previously, try to remove the new lamp and try with the older lamp.
If all these steps don't work then it is advisable to have the projector taken for service.
How do I do a hard reset on a optoma uhd55 projector.
To perform a hard reset on an Optoma UHD55 projector, you will need to locate the reset button on the projector. This button is typically located on the back of the projector, near the power cord. Press and hold the reset button for at least 10 seconds, or until you see the projector's LED light begin to blink. Release the button and the projector will reset to its default settings.
