20 Most Recent Sony Walkman NWZ-B103F MP3 Player Questions & Answers
I transferred a couple mp3's
"Write Protection" is a definate problem, but may be solvable (short of reformating) by checking the original files which, most likely, came from a CD copy. To see the attributes, right click on the icon and go down to select properties. There you will find "read only" highlighted for both the album folder and its sub files or songs. At this point the trick of avoiding "write protection" is to select the "read" attribute to unselect "read". Then select "Apply" and a window pops up showing boxes, one of which will say apply to folders, sub-folders or files, etc. Click on that box, then click on "OK". You will notice that the folder "read" attribute will remain highlighted, but that the subfolders' attributes do not!! (This is for Windows XP) At this point proceed to copy this folder OVER the same folder. You will be asked if you want to overwrite the existing folder with the same name. YES, please. The files will be replaced with identical file data, except the "read" attribute will be blank or unhighlighted, and NOW you can delete the folder.
9/18/2017 5:27:49 AM • Sony Walkman... • Answered on Sep 18, 2017
2answers
Sony Walkman Mp3 player
Use Windows Explorer to delete the songs you don't want.
4/4/2016 6:14:23 PM • Sony Walkman... • Answered on Apr 04, 2016
0answers
2answers
My sony 4 gb walkman
with a pin,on the back hole just reset it
6/26/2013 7:28:29 AM • Sony Walkman... • Answered on Jun 26, 2013
Sony Walkman NWZ-B162F MP3 Player won't turn off
I was also facing the same problem, and while going with some hit and trials, was able to find a solution for this as following: power can be switched off by holding the main key for long, the key which is used to select the folders, that is, the center of navigation key. Hope it helps.
11/8/2012 7:06:20 PM • Sony Walkman... • Answered on Nov 08, 2012
2answers
Can't delete write protected files
Try this method to delete your write protected files
Deleting Files,Pictures,Videos,Audio Books, etc. from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal
Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that
you do not want this will highlight the files/songs you do not want,
release, right click and then click on "Delete"
Now your mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Please rate me
7/30/2012 5:21:05 AM • Sony Walkman... • Answered on Jul 30, 2012
I had my sony walkman
Please try these steps:
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
Thanks.
gylacz
8/25/2011 6:27:58 AM • Sony Walkman... • Answered on Aug 25, 2011
Sony NWZ B153F Mp3 player
Your pc should have windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
Thanks.
gylacz
8/11/2011 6:35:35 AM • Sony Walkman... • Answered on Aug 11, 2011
I need the firmware and
http://esupport.sony.com/US/perl/swu-list.pl?mdl=NWZB103F
8/6/2011 5:50:46 AM • Sony Walkman... • Answered on Aug 06, 2011
2answers
Boot error on my NWZ
I hav a (sony mp3 player)DIgital music player nwz-b153f for past one month. today, im jus getting "POWER OFF" in my display and no other keys are functioning. the usb is also not detecting. plz assist me to rectify the problem. plz..
-saravanan.M
9942099626.
chennai.
7/13/2011 9:56:11 AM • Sony Walkman... • Answered on Jul 13, 2011
I have a Sony MP3
It means the Digital Rights to the song have expired.
From Sony's site:
"This issue may occur if the license for the track you are trying to play has expired on the device. If you currently subscribe to a music subscription service, connect the device and sign into the account to refresh your license to allow for playback. You may need to do this once during each billing period to listen to the subscription music you have transferred. If you are no longer a subscriber to the service where you downloaded the file from, you can delete the song from your portable player to prevent this error from occurring each time you try to play the song back."
7/12/2011 4:47:35 PM • Sony Walkman... • Answered on Jul 12, 2011
Sony Walkman NWZ-B103F MP3 Player Logo
67 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
Walkman Sony
  • Walkman Sony
Most Popular Question
  • Audio Players & Recorders
