20 Most Recent
ASUS VW193T Monitor Questions & Answers
Monitor
Does it occassionally turn on or does not turn on at all? I advise that you try a hard-reset(disconnect completely from power supply for about 2 hours). If it doesn't work then you will have to get a replacement inverter board.Let me know how it turns up so that i can assist you further. Thanks for using Fixya.
I would like to reduce brightness on my ASUS
Actually, the problem isn't with the drivers. Right click on the battery icon in your system tray. Select "Power Options" (NOT Power4Gear eXtreme). On the right panel, select "Adjust the display brightness." Then, select "Change advanced power settings." Scroll down and open up the "Display" box. The options that are affecting your screen brightness on battery are "Allow SmartDimmer to reduce my brightness after," "Have SmartDimmer reduce my brightness by," and "SmartDimmer full-screen video mode." Playing with the percentages in these boxes will affect how your screen brightness adjusts itself. To get my screen to stop re-brightening itself, I changed "Allow SmartDimmer to reduce my brightness after/ On Battery:" to 100%. I then changed "Have SmartDimmer reduce my brightness by/ On battery:" to 0%. Finally, I set "SmartDimmer full-screen video mode/ On battery:" to Maximum Power Saving. This should solve your screen-rebrightening problems even with the 163.44 drivers (I use those too). Please Rate.
Thanks,
Anand
Monitor says no signal
Fix the power cord firmly! hold it and fix it such that you wont get a shock! also fix the cord from monitor to CPU firmly! I prefer you to turn off you computer..clean the power cord by blowing the dust on sockets and pins and then fix it firmly and turn on computer again! Make sure power is not running in the cord while you clean it!
Problem with geforce 8400 gf
The native resoltion for this monitor is 1440 x 900 @60Hz for best picture. Are you able to set your PC resolution to this number?
My asus will not recognize
Hello and welcome to Fixya!
U will need to remove the computer side panel (1st disconnect power cord from computer or wall, very important) and remove the silver button battery for the CMOS on the main "motherboard", this is what maintains the memory of the password you installed, leave the battery out and then wait for 5 min's and reinstall, password is erased
