20 Most Recent GE Profile Spacemaker II PEM31 Microwave Oven Questions & Answers
When I enter the cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
See these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
7/7/2015 5:07:23 PM • GE Profile... • Answered on Jul 07, 2015
0answers
0answers
0answers
F2 code
Be the first to answer 12/19/2012 3:18:26 AM • GE Profile... • Posted on Dec 19, 2012Be the first to answer
How do i defrost
you need only select Defrost in your control panel. However read your instruction manual or download from www.fitness.manualsonline.com or www. retrevo.comGod bless you
7/14/2012 12:32:14 PM • GE Profile... • Answered on Jul 14, 2012
After I microwave the light stays on and the turn table stays turning whats wrong?
From the description the problem is in one of the door switches, usually caused by food partical build up, or ware. Each switch will need to be disconnected and tested.
3/8/2012 2:45:12 PM • GE Profile... • Answered on Mar 08, 2012
0answers
Won't turn off. Light on and fan running but not
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
2/22/2011 3:16:46 AM • GE Profile... • Answered on Feb 22, 2011
Newly installed GE profile pem31 microwave starts
hello,
this is a simple function that you should be able to carry out your self
from the statement above this means that your oven maize have disconnect from the element position i.e the wire have been disconnected from the heater
what you need to do is that unscrew your microwave trace the wire to the heater you will surely fine were the wire is been disconnected from the heater
then you have to huck up the wire back to the element (heater) the wire mention above will be in red and others can be in different color
please when doing make sure that all form of power supply is disconnect from the microwave to avoid accident
thank you and thanks for using fixya.
1/29/2011 4:35:44 PM • GE Profile... • Answered on Jan 29, 2011
The microwave DE68-03218B is running when the door
thats pretty cool
11/30/2010 9:58:46 PM • GE Profile... • Answered on Nov 30, 2010
GE Spacemaker II START button
hello,
for the button of the oven not to function here are likely problem that most have contributed to the problem below
Problem: No response to any buttons on touch pad.
Possible causes:
  1. Door is not closed (some models).
  2. You waited to long (open and close door to wake it up).
  3. Controller is confused (pull plug for a minute or two to reset).
  4. Defective interlock switches.
  5. Faulty controller or its power supply.
  6. Touchpad or controller board contaminated by overenthusiastic cleaning.
  7. Defective/damaged touchpad.
hope this help?
thanks for visiting fixya.
10/30/2010 9:18:29 PM • GE Profile... • Answered on Oct 30, 2010
My microwave top oven won't heat and there's a
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jk4
9/30/2010 5:02:02 PM • GE Profile... • Answered on Sep 30, 2010
It is making a lound noise and no longer heats
heatman101
dgh
9/30/2010 2:39:20 PM • GE Profile... • Answered on Sep 30, 2010
Have a GE "Spacemaker II Sensor" microwave oven.
you will need to find the source of the burning. it could be a cheap fix or more involved depending on the component. it could be a transformer, h.v.diode, magnetron, etc. if the diode is shorted, there is a good chance magnetron is defective too.
8/31/2010 2:12:57 PM • GE Profile... • Answered on Aug 31, 2010
Microwave buzzes and does not work
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
3/7/2010 2:14:50 AM • GE Profile... • Answered on Mar 07, 2010
GE Profile Spacemaker II PEM31 Microwave Oven Logo
47 questions posted
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
SpaceMaker GE
  • SpaceMaker GE
Most Popular Question
making lound noise no longer heats
  • Microwave Ovens
