20 Most Recent
HP Pavilion dv6000z 15.4" Notebook Laptop PC 64 X2 Duo Core TL-56 1.80GHz, 1GB RAM, ... PC Notebook Questions & Answers
Help please hp pavilion dv6000
if you have change your screen before and it contnues then change your signal cable(vga), this is connected from board to LCD (screen).
I have a password problem on my laptop,but not
If you are talking about the password that is just ask when the comp starts....You can try this...
The power-on
password prevents use of the computer until the password is entered. The
setup password prevents unauthorized changes to
Computer Setup. To clear the
passwords, you must remove all power from the
system board. If you do not know the
passwords, use the following procedure to clear
the password:
1. Remove all battery packs.
2. Disconnect the AC power.
3. Remove the real-time clock battery.
4. Wait thirty minutes.
5. Reconnect the AC power. DO NOT INSTALL THE
BATTERY!
6. Restart the computer. During Power-On Self Test
(POST), a â 162 System Options
not setâ message appears.
7. Shut down the computer, then disconnect AC
power again.
8. Replace the real-time clock battery.
9. Install the battery pack(s).
10. Reconnect the AC power.
11. Start the computer.
Hello my laptop having unable to startup
if you can see some msg after power on then screen and CMOS BIOS is OK...
try changing the CMOS battery inside....(battery model will be CR2032 i guess so...it will be aprox the size of a dime(US 10 cent coin size)
or
RAM is corrupt...change the RAM cards inside...ensure that the new RAM is compatible...
pls leave a feedback...
reg
My mic doesnt seem to work at all
It is due to the loose contact in your PC's mic jack. If you are a technician you can replace it yourself, otherwise contact a laptop technician.
Vis
Hi
first u take your all backup from system then boot from xp2 and delete partition then install xp2
more help then ask me
Harry
Touchpad issues
click on to start go to run and in run type msconfig
then click on to services check for the name of touch pad on your computer ,,,and then click on to that and it i will work
I have a HP laptop.
Try to wiggle LCD a little. If it starts to work in certain position, - LCD needs to be replaced.
Each times i tried to download a software.music,
Your security settings may be set too high. If you open your internet explorer and click on
Tools-Internet Options-Security
then click reset all zones to default
- this should solve your problem.
Re-download the current drivers from HP and re-install them.
Clean the little glass bulb in the DVD drive with Alchohol and a q-tip, if you can.
It is acting like it is rejecting the drive and or disk. You need to minimize what possibilities are making this happen. Doing the above will do that.
-t
Over heating problems
If you are confident with the insides of laptops, remove the panel to expose the heatsink, and clean the fins on that. If it has pulled in a lot of dust, then no matter how clean your fans are, it won't be able to pull cool air through the heatsink and over the chip, leading to an overheat condition.
HP pavilion wireless uninstalled itself
I have the exact same issue with a wireless card. Most likely the card is bad. The driver is not uninstalling itself, it simply can't see the hardware and is therefore not listed. Change out the card, and it should resolve the issue.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Battery problem of hp dv6000
The battery has a limited life span, and it sounds as though this one has reached its end. My own battery did the same thing. Though it had never been used, I bought it with the laptop as an extra, and after using for less than two months, it gives me no time at all now. Replacing the battery is your only option.
Please post back if you need further help, otherwise thank you for using and rating FixYa!
Am planning to buy!!
those computers run from 85 to 264 VAC with the same input..only difference is the interface connector, which you can get in Canada..I do same thing with my US computer here in Euroland.
