20 Most Recent HP Compaq 2510p Notebook PC Questions & Answers
Recover BIOS at Compaq 2510p
Power on password removeeade9555-5164-4a8d-9032-9b2e8e14e8d1.jpg16569205347033985712996167254391-2qghwvbkuqv52va3uqdqimj3-d-2.jpg
7/4/2022 11:44:40 AM • HP Compaq 2510p... • Answered on Jul 04, 2022
1782 disk controller failure
learn to google yet https://search.brave.com/search?q=HP+1782+disk++error&source=web brave search , finds it, 1 seconds labor.
5/20/2022 11:03:33 AM • HP Compaq 2510p... • Answered on May 20, 2022
My Laptop doesnt turn on how do i fix this...help!
Already answered today - take battery out and try.
3/17/2015 5:40:20 AM • HP Compaq 2510p... • Answered on Mar 17, 2015
My Laptop does not turn on anymore... When i insert the ac adapter a the power light flash instantly and gone... but my laptop doesnt charge or turn on...:( i have tried replacing the adapter but n
Take the battery out and run directly from the ac adapter. If it works then the battery is blown up. But if nothing happens and there is no activity then motherboard fuses may have blown or worse the motherboard is faulty. Look for another laptop in that case.
3/16/2015 10:14:37 AM • HP Compaq 2510p... • Answered on Mar 16, 2015
Hp 2510p not charging
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly. Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose. Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery.
For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter.
In most situations it's a bad battery.
hope this helps
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps
8/8/2014 7:57:04 PM • HP Compaq 2510p... • Answered on Aug 08, 2014
HP Compaq 2510p won't boot
It's a sign of RAM failure. Replace your RAM.
5/31/2014 5:48:09 AM • HP Compaq 2510p... • Answered on May 31, 2014
Shortcut key unlock the touch pad
there is either a small button above the trackpad or else call hp
5/1/2014 12:11:50 AM • HP Compaq 2510p... • Answered on May 01, 2014
0answers
How to unlock the touch pad
There should be a touchpad on/off button on the top row of lights above your keyboard. It is a square icon, tbh it looks like a small touchpad. If this doesn't work there may be a problem with a driver. In which case go here - http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=3355636& then choose your operating system. First try the quick launch buttons driver, then try the synaptics driver. Post back if this doesn't help
3/15/2014 1:29:06 PM • HP Compaq 2510p... • Answered on Mar 15, 2014
Wireless switch not working
Wireless card not present or not working
1/16/2014 8:50:13 PM • HP Compaq 2510p... • Answered on Jan 16, 2014
Drivelock multibay password when i switch on a hp compaq nc8230
hi please I have my Laptop hp compaq nc8230 who requiert drivelock. anytime when I swith on I waiting for longtime.I getting a message drivelock multibay password.I don't know that I do.thank
7/22/2013 2:59:39 PM • HP Compaq 2510p... • Answered on Jul 22, 2013
Freezes when on Battery
sounds like your batt(i asume is a lithium) is not givivng enough amps to run a screen and only thing u can do is unfortunatly replace the battery, u can try seeing if it completly fried, by unpluging cord...hitting start key when its frozen, then plugging back in to unfreeze. if the start menu is up that means your battery has amps, just not enough to run ur screen, if that dosnt work, your battery is shot, and you need to replace, either way, you need to do this, sorry i wish i had more options.
6/19/2013 8:44:20 PM • HP Compaq 2510p... • Answered on Jun 19, 2013
It ask for bio pass that i don't know ?
You could try to remove the CMOS battery for a few hours, sometimes that will reset. Contact HP for a one time BIOS password or ask the person you got it from.
4/10/2013 2:47:25 AM • HP Compaq 2510p... • Answered on Apr 10, 2013
Speaker does not work
Check the MUTE button is not selected and the volume slider is moved to a high volume level.If this is not the problem then reinstall the audio driver. You can download the device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: - www.compaq.com/country/cpq_support.html
3/28/2013 1:32:33 PM • HP Compaq 2510p... • Answered on Mar 28, 2013
Plug in not charging
this can mean that the battery of your system has failed and needs replacement. you may try to test the battery on another laptop or try another working battery with your laptop. If battery is working on another system, or if another battery has the same result on your laptop, next things to check and try is another charger. If that does not work, the next point of failure would be the dc input connector on the laptop which may also be part of the motherboard and needs to be replaced.
6/9/2012 10:22:33 AM • HP Compaq 2510p... • Answered on Jun 09, 2012
HI I am Ramesh from
You should try www.unlockbiosrecovery.com and for $20 they will send you a bios master password that will clear any bios passwords set. I use them in my laptop repairs quite often.They also unlock hard drives on laptops for most brands.
9/1/2011 5:34:33 PM • HP Compaq 2510p... • Answered on Sep 01, 2011
HP Compaq 2510p Notebook PC Logo
55 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
laptop doesnt turn fix help
  • Computers & Internet
