20 Most Recent
Sony Toshiba Qosmio F45-AV411 Notebook Questions & Answers
How do i replace a toshiba qosmio f45-av411 lcd
First remove the battery from te laptop. Locate all the screw covers (in the front side) with the watch maker screen driver. There might be four of them. Once you remove the screw. covers, remove the screws and remove the front bezel. You can now separate eh front bezel. Locate the screen assembly. Remember, there might be laches. So, be careful not to break them. You will see the frame scrwes after this with the vedio cable quite visible. Just remove them to find the invertor. Thats it.. You have removed the LCD screen.
Hope this helps.
Regards,
Hari
Can read but can't burn dvd drive in toshiba
IF YOU HAVE WIDOWS VISTA, IT WILL WONT ALLOW TO MAKE COPIES, OR THE DISK YOU ARE BURNING IS RIGHT PROTECTED...IF THESE ARE NOT THE PROBLEMS CHECK YOUR BURNING SOFTWARE SETTINGS...OR LAST THING IS TO CHANGE YOUR DRIVE
Audio driver for high defination
Software should be on http://support.toshiba.com. (Under the tab downloads)
Here is a direct link :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1754951&rpn=PQF43U&modelFilter=F45-AV411&selCategory=2756709&selFamily=804517
Select the Realtek Audio driver there.
I need to reset the
To reset the BIOS read the information from this
link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Have a Toshiba Qosmio F45-AV411 and downloaded
Try to boot up the computer using safe mode first. Keep on tapping the F8 key the moment you turn on the computer. If your computer wont boot to safe mode then you need to re-install windows 7.
How to replace wireless card
The wireless card is either under the keyboard or under one of the obvious doors on the bottom.When located be careful when removing the antenna wire that snap on to the card its self.
How to bootable the cd
when the PC is powering up, press either the F2 key or delete key, which should ge tyou into the BIOS. Use the cursor keys to get to the "Boot section", then choose CD/DVD as the first boot device.
Toshiba qosmio f45-av411 how do i reset to factory settings
There is no magic button that i know of that fixes those faults Returning it to factory defaults doesn;t reinstate broken parts. To me it sounds like a board fault and that some jiggling you did temporarily caused it to make contact for a while. It could be a loose cable connecting the problem components to the main board, it could even be a cracked M/Board. It would have to be opened to check for that. I don't advise you to try it either as many before you have ventured into laptops and never been able to get them back together again.
Putting a new disk in sounds to me to be a waste of money on a machine that has so many problems.
If the unit is so valuable to you I would be biting the bullet and having it repaired properly, not mucking around hoping you get it right by a fluke, that way you will end up spending more thanj $300.
You can buy a new Toshibt Satellite Pro for $400 after cashback. So why persist with a dying machine with no warranty and a 100 problems?
Please rate our help++++Thanks for using FIXYA
Crashed error 03-FFFF-OOOO
if that error occurs while attempting the recovery, typically it indicates a read write error on the hard drive. replace the hard drive and see if the recovery finishes.
(although i have only seen this problem with failing hard drives)
DVD drive replace
If its in a desktop ist simple you need to unscrew the back panel and then unscrew the side cd drive panels , remove the IDE cable from Scocket
