20 Most Recent Toshiba Satellite Pro A210-EZ2202X Notebook Questions & Answers
The drivers for the Card Reader should be in? Open Device Manager and check Card Reader. Did the Laptop come with Windows 8 or did you do a OS upgrade? Try Toshiba Support : http://www.toshiba.eu/innovation/generic/SUPPORT_PORTAL/
Toshiba... | Answered on Apr 19, 2013
Age and dust accumulation. try blowing the case out or get a vacuum cleaner and clean out all the ports. If this doesn't work, you may have to take it to a computer repair shop to get it cleaned and serviced properly. The heat paste on the processor may have dried out and be causing an overheat.
Toshiba... | Answered on Apr 13, 2013
when starting your laptop togglr F8 key and then start in safe mode and then go to system restore and pick an earlier date and follow instructions
Toshiba... | Answered on Jan 19, 2013
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Replacement Toshiba Satellite L655 AC Adapter 65Watt 19V 3.42A
Replacement Toshiba Satellite L655 AC Adapter 75Watt 19V 3.95A
Toshiba... | Answered on Dec 19, 2012
When I clicked on the link for Toshiba Laptop's Solution it directed me to the findandtry website that has a very poor Web of Trust reputation and would appear to be a **** site, so BEWARE!
Toshiba... | Answered on Oct 28, 2012
Uninstall webcam software , Restart Re instal webcam software.That should fx it
Toshiba... | Answered on May 08, 2011
in the VGA options make rotations to normal
i hoe it will work
mvmanish
Toshiba... | Answered on Apr 10, 2011
You can reset the password if you don't know it. To reset the BIOS password read the information from this link http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
Toshiba... | Answered on Feb 04, 2011
Turn off hibernation. If its not resuming from hibernation without rebooting then is very possible it may stop loading even after a reboot.The fact that you have to reboot it to be released from hibernation could indicate a failing hard drive.
Toshiba... | Answered on Jan 26, 2011
TRY F10 ON BOOT TAPP FAST ,,IF NO JOY TRY OTHER NUMBERS FROM F9 UPWARDS ,IF NO JOY ADD ALT ASWELL PLUS F9 F10 AND SO ON HOPE IT HELPS IF NOT CHECK YOUTUBE FOR UR MODEL SHOULD FIND VID THERE
Toshiba... | Answered on Jan 08, 2011
REMOVE POWER CORD AND BATTERRY FOR FIVE MINS THEN RETRY
Go to the folowing link and Download/Install the Current Updates for your laptops OS. That should take care of your issue..
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1854875&rpn=PSAFHU&modelFilter=A210-EZ2202X&selCategory=3&selFamily=1073768667
PLEASE DON'T FORGET TO RATE MY SOLUTION, OK? THANK YOU :)
Toshiba... | Answered on Oct 18, 2010
It could be one of the following:
1. Bad/damaged power jack.
2. Bad motherboard.
Visually inspect the power jack to make sure it is not broken or damaged.
Test voltage on the power jack to make sure it is not damaged.
Toshiba... | Answered on Sep 26, 2010
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Toshiba... | Answered on Sep 18, 2010
Toshiba Satellite Pro A210-EZ2202X Notebook Logo
55 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
toshiba satellite l655d
  • Computers & Internet
