20 Most Recent
Toshiba Satellite M115-S3094 Notebook Questions & Answers
Missing dvd driver
after you update the BIOS
update the DVD firmare
update the driver for flash reader...i believed you have Texas instrument reader and they have update driver for xp and vista
after you update the driver ..check also the hardware update for microsoft...do custom update when you access windows update
11/2/2022 5:39:16 AM •
Toshiba...
Answered
on Nov 02, 2022
I have a toshiba satellite M115-s3094 and the dvd
Go to Toshiba Support online and enter your model number under product support. Download the drivers for the dvd drive.
Follow instructions in
this article &
this article to update the drivers.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
12/6/2021 6:34:49 PM •
Toshiba...
Answered
on Dec 06, 2021
How to adjust the brightness on theMonitor
Press FN key (second key at bottom from left corner of KBoard) and hold it down and press F3 (fourth key button from top left of keyboard) to increase brightness and F2 to decress brightness. Should see a picture of a sun with an up or down arrow on the function key.
4/26/2015 7:30:54 AM •
Toshiba...
Answered
on Apr 26, 2015
Wont go past boot menu
your dvd rom or your disc might not working properly. there can be one more problem that you RAM is creating problem just pull out RAM and clean it then insert it and do the process again.
11/13/2014 3:19:26 PM •
Toshiba...
Answered
on Nov 13, 2014
Toshiba sat no video
firstly go to this link given below and download all drivers for your notebook . Then install them and restart your notebook and if it's still not working then it's a hardware problem. You might have to change your notebook's display.
Satellite M115 S3094 Support Toshiba
11/13/2014 3:09:04 PM •
Toshiba...
Answered
on Nov 13, 2014
Reset bios password
Go to command prompt OrPress and hold window key and press "R" keyType:- cmd and EnterType:- debug and EnterType:- o(not zero) space 70 space 2e and EnterType:- o(not zero) space 71 space ff and EnterType:- Q and EnterRestart your computer and check Bios password should be removedYou can use hiren boot 15.2 software and can be easily download
5/12/2013 12:14:57 AM •
Toshiba...
Answered
on May 12, 2013
Audio problem on toshiba satellite m115-s3094
Most likely no. I would check the model of the laptop and go to the company's webpage to download the drivers. If you'll list the model of the computer I'll try and provide you with a link to all applicable drivers that you would need.
4/28/2013 5:28:43 AM •
Toshiba...
Answered
on Apr 28, 2013
How to reinstall windows XP
Your model Toshiba notebook has a SATA hard drive. The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
3/28/2013 5:01:45 AM •
Toshiba...
Answered
on Mar 28, 2013
Product key for windows xp
The product installation code is on the Windows label attached to the bottom of your laptop.
12/15/2012 1:14:33 AM •
Toshiba...
Answered
on Dec 15, 2012
No operating system how do I insert the missing operating system
You can not inset operating system like CD/DVD inserting! It is special kind of software that runs your computer to make an environment for you to work. First you need a Boot able Operating system cd/dvd. This laptop normally comes with Microsoft Windows xp Media Center Edition. You may choose professional. Now insert this disk into your laptop, boot form cd/ dvd, and start installing...After finishing installation properly , you can remove disk from your laptop and your operating system will be inside of your laptop. If you are new you can not do this things along, Try to read manual of your laptop to select boot device to boot from cd/dvd and learn how to setup windows or other operating system you want. Let me know updates.
6/25/2012 6:53:43 PM •
Toshiba...
Answered
on Jun 25, 2012
