20 Most Recent
Toshiba Qosmio F45-AV410 Notebook Questions & Answers
Password removal
remove the CMOS battery for a few days then put it back and try that.
Overheating, sometimes i see the fan go on and off
Under load the fan will kick in and stop as the temperature gets hot. This is normal.
If it is doing this on a reguar basis, you can do the following
1.) Download a copy of a hardware monitoring tool (everest is good) as a trial, note the indicated temperatures that appear on the toolbar, up to 60 degrees is ok under load, after that, you have an overheating problem.
2.) Either take the laptop to a shop and get it cleaned out (dust and dirt accumulate in the fan and coooling matrix), or try this yourself. You can try vacuuming the intake and outlet ports for the fan, but this is not the best solution.
3.) Obtain a USB cooling pad, these are ludicrously cheap on the lies of ebay at less than £4.00 delivered from some suppliers and reduce operating temperatures by 15-20 degrees if placed correctly
Finding Sata drivers
Ok, let me see if I've got this right, you want to replace vista? but you need the SATA drivers? To do a dual boot, you usually need to install XP first, and Vista second. As for the SATA drivers, if the XP cd boots up and allows you to edit the partitions, then the SATA driver is already integrated. And here is the download page for your laptop
Qosmio® F45-AV410
Toshiba quosimo f45. laptop wont boot at all ,fixed once by them
hi there,
dont panic brother,
try theses things.
--> take out battery
--> connect the power cable
--> wait for a minute
--> turn it on
--> it will work
if not
--> take care power cable out
--> put the battery in
--> turn it on
--> and it will work (try to move the lid up and down)
if not
--> charge the battery dont turn it on
--> when its full take of the power cable
--> wait for 30 sec
--> turn it on
--> it will work ((try to move the lid up and down)
if not
--> keep the power cable
--> turn it on
--> it will work (try to move the lid up and down)
best of luck
Error Occurs
I'm going to ask a stupid question. After you run the recovery and the machine reboots, are you getting a prompt to "press and key to boot from CD"?
If so, don't press a key and see if Windows (recovered) will boot.
If not, I'd say you probably need to re-run the recovery and choose a clean Windows install ...or at a minimum, a repair.
Hope this helps - please remember to rate :)
When laptop says no bootable device
It means that you do not have a hard drive that can be booted to start the OS, or that your had drive is defective, or the boot sector of the hard drive is missing or corrupted.
Wireless capability turned on
You just got wireless turned on ?
Does this mean you just added a wireless router to your existing wired network ?
You may need to turn off the DCHP server in the wireless Router and give it a unique ip address eg if wired router is 192.168.0.1 then make wireless router 192.168.0.2 with gateway ip set as 192.168.0.1 then make wired dhcp router not lease out 192.168.0.1 - 192.168.0.20 make subnet mask the same also for each router.
Beep codes
Did you solve the problem? I have the same here, in Brazil.
I have a rj111 cord jsrAA.where do i plug back in
On the right hand side after the USB sockets there is a drop down flap. Underneath are the RJ11 modem and RJ45 network sockets.http://www.notebookcheck.net/fileadmin/_processed_/csm_Anschl._rechts_01_129c1d9a1d.jpg
I had friends over and they were logging into
Reboot your computer, OPEN YOUR CHROME WEB BROWSER, AT THE TOP RIGHT HAND CORNER CLICK THE THREE BARS, SCROLL DOWN TO SIGNED IN AS CLICK ON IT, SCROLL DOWN TO USER, SIGN IN AS ''NEW USER'', CLOSE BROWSER..OPEN FACEBOOK AND LOGIN...
