20 Most Recent IBM ThinkPad T61 Notebook Questions & Answers
Usb ports don't work
did u disable the USB port in Device manager, if so then enable it and check if there is any yellow ? or ! mark in it
2/13/2010 6:36:38 PM • IBM ThinkPad T61... • Answered on Feb 13, 2010
Cant connect to the nett on ibm t61 thinkpad dont know how on lap
There are so many answers to this it would take a month to type them all. 1. Make sure you have sometype of connection to the laptop either Phone line or network cable or wireless signal. 2. Based on the connection available make sure you have the correct software for the connection installed. 3. If you have a network connection ensure you have setup a network connection on the laptop. If you are using the modem make sure you have the proper dial-up software installed and setup. 4. If you have no idea what I am talking about with any of this, I recommend you go to Best Buy or any other computer tech shop and ask them to set the connection up for you in order to make sure it is done correctly.
11/20/2009 9:31:58 PM • IBM ThinkPad T61... • Answered on Nov 20, 2009
Remote printing was working and then it stopped.
If this is a network printer. You can reinstall the drivers that came with the printer as a local printer, then go into control panel open the 'printers and faxes' right click on the printer that you reinstalled, 'properties' go to ports tab, select add port, -> 'standard tcp/ip port' -> 'new port' -> next -> put in the ip address for the printer, it will be the scheme of you subnet for example if your ip address for your computer is set to 192.168.1.1 you would use the ip address for the printer port of 192.168.1.2. after that is done press next-> after that you will be set as a network printer. Try to print a test page.
If this does not work, you can install the printer locally on a separte computer, such as your home pc, and make the printer a share. Then simply add the share printer on your laptop. for example; after you install the printer on your home pc, go under control panel, -> right click the printer -> sharing-> enable printer sharing... -> Next -> You will be prompted on the sharing tab-> select 'share this printer' -> type a share name, such as 'Lexmark2' -> click ok. at this point you will see a hand under the printer, showing it is shared.
Note: you will need to get the computer name of the pc that the printer is locally installed, your home pc. for this example lets name the pc 'home' you can find the name of your pc by right clicking on my computer and select properties. go to the computer name tab.
also remember we named the printer share 'lexmark2'
now go to your labtop, go to the control panel and select 'printers and faxes' select add a printer on the right column. a windows will pop up, click next -> select 'A network printer, or printer.....' click on the radio buttion that reads 'Connect to this printer (or to browse.....' should be the 2nd option. this is where you are going to use the computer name and printer name.
put in
\homelexmark2
click next -> then finish
print a test page, from your labtop.
If you need further help please contact me.
[email protected]
Dont forget to vote!
9/6/2009 5:30:26 AM • IBM ThinkPad T61... • Answered on Sep 06, 2009
Scrollbar moves down
NO PC MODEL TOLD AT ALL NOR ANY OS. WINDOWS VERSION WHAT? THAT IS WINDOWS FEATURE TURNED ON CALLED AUTO SCROLL. LEARN TO ASK AT Microsoft .com here I will do that for you now first google hit. (control panel mouse settings) 'https://answers.microsoft.com/en-us/windows/forum/all/disable-auto-scroll-feature/b71585fb-c138-4573-953b-0c444da49c03
1/18/2022 7:02:26 PM • IBM ThinkPad... • Answered on Jan 18, 2022
How to change the languae to english
unable to answer since no information given
8/27/2019 11:47:16 AM • IBM ThinkPad... • Answered on Aug 27, 2019
Display hardware trouble ibm thinkpad
hi have a look at this pdf it shows you everything inside your comp; also it could be a driver issue for you video card https://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t6189.pdf
11/1/2017 7:22:16 AM • IBM ThinkPad... • Answered on Nov 01, 2017
0answers
How do i connect to a printer
Hi Jenelle I think we will need more information to be sure to fix this problem, like the model of the printer and are you trying to connect to it with USB cable or through network (with LAN or with wifi). in most cases anyway make sure the wires are connected correctly (USB) and download the below link to identify and install your printer if it's not installed correctly. press the identify now button after connecting it with USB. HP Support Software Drivers
5/23/2016 6:58:11 AM • IBM ThinkPad... • Answered on May 23, 2016
Cannot boot from any device
First, make sure your drive is bootable. Then, enter the bios and change the boot sequence.
3/13/2016 8:58:45 AM • IBM ThinkPad... • Answered on Mar 13, 2016
For got my password to my laptop so u can not get log in
Boot your laptop with the Windows installation DVD, and you can reset the password easily with this trick: http://www.forgotwindowspassword.com/reset-lost-windows-password-without-reset-disk/ The tutorial requires a bit complicated steps. If you're a computer novice, you'd better call a friend who is a computer geek and ask him to help you remove the password.
3/10/2016 2:35:09 PM • IBM ThinkPad... • Answered on Mar 10, 2016
2answers
How to change the language to english
If it is the whole's computer language, you have to re-install the operating system, but get a copy that is in english language.
3/9/2016 3:32:56 PM • IBM ThinkPad... • Answered on Mar 09, 2016
I SET UP MY EMPLOYEE ACCOUNT BUT NOW I CANT GET PAST THE LOGIN SCREEN HELP PLEASE
if this is an employee account in a company operation then contact the company IT people for assistance If you are the employer setting up employee self serve accounts get IT help or cancel out and start again following the procedure exactly
1/23/2016 5:35:45 AM • IBM ThinkPad... • Answered on Jan 23, 2016
The screen will not turn on the panel lights will come on the fan works but the screen will not come on
Hello, It sounds like your screen , or power supply is out. Did this get hit with a power surge or lighting. If so will have to taken in for repair.
11/1/2015 12:43:22 AM • IBM ThinkPad... • Answered on Nov 01, 2015
IBM T43 THINKPAD POWER CORD
Grab the T43 HMM here: http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t6193.pdf Goto Page 211 for power cords.
9/8/2015 2:40:51 AM • IBM ThinkPad... • Answered on Sep 08, 2015
IBM ThinkPad T61 Notebook Logo
5 questions posted
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad IBM
  • ThinkPad IBM
Most Popular Question
usb ports dont work
  • Computers & Internet
