20 Most Recent Lenovo 3000 N100 CoreDT2080 VB PC Notebook Questions & Answers
3answers
Low sound in lenovo 3000 N200
My Lenovo 3000 N200 not recognize an WD Scorpio Blue 160GB sata
10/29/2020 12:08:53 PM • Lenovo 3000 N100... • Answered on Oct 29, 2020
Soun Drive+Task Manager related problem
Dear Gopal,
1.Pl download your laptop sound driver from lenovo web site and install it then not working sound so your laptop require to check physically sound card working or not working in laptop motherboard.
10/12/2020 9:20:06 AM • Lenovo 3000 N100... • Answered on Oct 12, 2020
2answers
How to install the hardware drivers and set the
Broadcom Wireless Driver (Windows Vista)
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_661.html
Broadcom Wireless Driver (Windows XP)
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_326.html
Intel Wireless Driver (Windows Vista)
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_310.html
Intel Wireless Driver (Windows XP)
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_1263.html
Just download them and run the setup file to install the drivers :)
If you found this helpful , please rate my solution below
Kind Regards
1234s282
8/18/2016 4:02:16 PM • Lenovo 3000 N100... • Answered on Aug 18, 2016
2answers
Wi-fi connection
Looked at the specs on your laptop and you have the wireless card included. I assume you have a router set up already or you have access to another wireless network. Follow these steps to access it from your laptop:
1. Go to START
2. select MY COMPUTER
3. Once in the new window, click MY NETWORK PLACES under the "OTHER PLACES" section
4. select the VIEW NETWORK CONNECTIONS link under the NETWORK TASKS section
5. RIGHT CLICK on your wireless network connection and choose PROPERTIES
6. click the WIRELESS NETWORKS tab.
7. make sure the "USER WINDOWS TO CONFIGURE MY WIRELESS NETWORK SETTINGS" box is checked
8. Click OK and close the window
9. RIGHT CLICK on your wireless network connection (the name of it) and choose REPAIR
10. if windows detects the wireless connection, you should see a bubble near the task bar
11. in order to begin using the wireless connection, open your web browser then enter your username and password (if required)
2/23/2015 1:33:49 PM • Lenovo 3000 N100... • Answered on Feb 23, 2015
Lenovo N100 does not switch to battery power
Batteries have a memory,
When the battery was new it most likely would run for 1.5 hours, but, since you didn't want the computer to go off, and you were by a plug-in, you plugged it in before it was completely or maybe sometimes not even halfway discharged. That is where it stated its "memory" - this got shorter and shorter = your battery "THINKS" it is totally discharged and reads as so.
There are programs on the web (can't advertize for pay programs or give you links to them - against the rules) - that will re-vitalize your battery to almost new condition by discharging it more and more till it is truly fully discharged, then will fill it back to like new charge time.
Or you can buy a new battery.
12/19/2014 2:59:59 PM • Lenovo 3000 N100... • Answered on Dec 19, 2014
Long beep at startup
Probable Causes Error Beep Codes Defective system board. Memory refresh failure. 1 Faulty DIMM or defective system board. Error occurred in first 64 KB of main memory. 2 Faulty DIMM. Read or write error occurred in first 64 KB of main memory. 3 Defective system board. Timer on system board malfunctioned. 4 Defective microprocesor. Microprocessor error. 5 Defective system board. Gate A20 failure. 6 Defective microprocessor. Microprocessor-execption interrupt error. 7 Missing or faulty video adapter. Video memory read/write error. 8 Corrupted system BIOS program or defective system BIOS chip. ROM checksum value does not match value encoded in system BIOS. 9 Defective system board. NVRAM shutdown register read/write error. 10 Defective microprocessor or cache card. Cache memory error. 11 Faulty video adapter. Video adapter failure. 12 Loose video cable connection or defective video cable.Faulty video adapter. No monitor connected. 13 14
5/18/2013 1:18:32 PM • Lenovo 3000 N100... • Answered on May 18, 2013
Want to stop someone else from reading my emails.
Go to www.gmail.com
You will find in right hand side boxes for username and password
enter your login name and password over there.
Now after logging in right top corner there is link for 'Settings' click on it that will open settings panel (u will find there General, Accounts, Labels etc).
In that click on second tab 'Accounts' will open 'Accounts' tab in that click on -->'Google Account Settings'(4th in vertical order).
This will open one window containing Personal information. There is link for change password. Click on it.
Then put your current password and then new password and then click on 'Save' button.
5/9/2013 3:54:15 AM • Lenovo 3000 N100... • Answered on May 09, 2013
4answers
My internet speed is slow.I connect it via bluetooth.
by any means even if the configuration of the system is also very good but still with the bluetooth you will not get the connectctivity speed like the broadband and that is same as with the wireless also you will not get the speed like you get from the broadband connection . as this is just the virtual connection with just give you the emergency support not like as usual cbroadband connectivity.
so that cannot be increased .
3/25/2013 7:25:09 AM • Lenovo 3000 N100... • Answered on Mar 25, 2013
How to connect my laptop with bsnl broadband through wifi
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. Usually a wifi enabled phone, computer, or whatever device, will recognize if there is wifi access near you. If not you may need to turn on the wifi on those devices. Usually those setting can be found in menus like Network Settings. Once it recognizes the network you will need the password if it is required. Just enter that in and you are set. Where you enter the password is usually in the same menu in which you turned on your wifi enabled device. if still no connection Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. Click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator. 1. Click Start, type services.msc and hit enter. 2. Locate WLAN AutoConfig service, double click on it to open its properties window. 3. Under General tab, change the Startup type to Automatic and click Start button. 4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx
2/18/2013 5:42:52 AM • Lenovo 3000 N100... • Answered on Feb 18, 2013
2answers
I don't know the bluetooth passcode to my Lenovo
try 0000 Four Zero's.
1/25/2013 7:30:37 PM • Lenovo 3000 N100... • Answered on Jan 25, 2013
WIFI
Have you tried right clicking on wireless adapter and enabling? It can also be done in Device Manager.
1/9/2013 5:17:23 AM • Lenovo 3000 N100... • Answered on Jan 09, 2013
2answers
No sound at laptop speaker but audio output is ok
I have lenovo notepad 3000n100 with winXP sp2.
I downloaded realtek audio from ibm site and installed.
Now sound is coming at my output port but the in-built laptop speaker is not giving any sound output.
The hardware is ok as the sound was coming at in-built speaker before formatting. The previous audio driver set up file i have lost.
Plz help.
10/5/2012 9:36:35 AM • Lenovo 3000 N100... • Answered on Oct 05, 2012
2answers
Sound problem
PROBLEM FROM YOU SPEAKER... KINDLY CHECK YOUR SPEAKER CONNECTION..
OR BOAR PROBLEM A LITTLE PROBLEM ONLY...
10/5/2012 9:34:39 AM • Lenovo 3000 N100... • Answered on Oct 05, 2012
3answers
How turn off numberlock on laptop
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.HKEY_CURRENT_USER\Control Panel\Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.0 = Num Lock is turned OFF after the logon.1 = Disable Num Lock.2 = Numlock is turned ON after the logon.
hope this helps
7/12/2012 1:23:26 AM • Lenovo 3000 N100... • Answered on Jul 12, 2012
Where i can get free download for driver for
Start here:
http://support.lenovo.com/en_US/downloads/default.page
The website will ask you for model number and OS. Then you should be good to go.
I hope this is helpfull.
8/25/2011 2:55:11 PM • Lenovo 3000 N100... • Answered on Aug 25, 2011
Lenovo 3000 N100 CoreDT2080 VB PC Notebook Logo
Popular Tags
100 questions posted
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
3000 Lenovo
  • 3000 Lenovo
Most Popular Question
soun drive task manager related problem
  • Computers & Internet
