20 Most Recent
LG 30 in Kitchen Series Dual Convection 5.6 cu ft Electric Range - LRE30955ST Kitchen Range Questions & Answers
My oven is not going
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Keep getting F3 and F5
Sorry to read about your problem, I hope this helps you out.
try to reset you circuit breaks, and see tif the problem comes back.
the codes mean you have a defective keypad/control board issue.
I suggest you contact a service company
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Hi, My LG Dual Convection oven is taking over one
mine too. it took 2 hrs to get to 300. Self cleaning does not get hot enough to clean. it seemed to work for a day after that, but is not working again. i got the error F-7 but can't locate my book to see what that means. the stove is only 1 year old....have you found an answer to your problem??
When using the convection roast, does setting it
Your range has the feature called auto recipe conversion,that means it will automatically adjust your settings to compensate for the changes when useing either convection modes, bake or roast,rest assured you turkey will turn out perfect with convection roast. Remember that raosting time will be slightly reduced also with convection roast bakeing. Have a wonderfull Thanksgiving and Holiday season. Good luck !
LRE30757sp\00 brand new is tripping circuit breaker
check your main/sub panel,you may not have enough amperage to supply this unit,is it larger than your previous unit?chk your total wattage of unit and devide by your input voltage to get the amperes drawn on unit then chk fuses/breakers/wiring to see if they can handle the load
I have not recipe book for lg mc-8048wr
You should contact the dealer from whom you purchase the lg Mc-8048WR microwave. It is your right to collect the recipe book and one CD explaining the cooking method etc. It is absolutely free with this model. so hurry and contact your dealer
LG Electric Range Oven Keeps Shutting Off
When you say "Just shut off" do you mean the circuit breakers would trip, or fuses would blow? If so, I would have an electrician check that the circuit is properly fused/breakered and wire sized for the amount of power required by the oven. If the installation directions say it needs a 50 amp service, it better be a 50 amp service.
If shutting off is just something within the oven, then get LG back out again, and let us know of what they say is wrong.
Oven shuts on & off: Control panel inop at times.
I've been battling with on and off inop problems on the controls of my range. sometimes a good cleaning or turning the circuit on and off has worked, but recently the start button and 1 of the burners stopped working. after surfing through many forums with the same problems, i found 1 with some solution advice that worked great so i decided to revisit some of the sites i surfed for info the forward the advice.....
the ribbon circuits get dirty and simply need tp be unplugged, wiped clean and reattatched. after doing this, my oven is good as new...i hope this helps:)
I want the Owner's Manual
Sir,
I have LG Convention Microwave & Grill multipurpose .
I want to make kahri biscuits how to operate it i do not know can i get help from you
thanks
adma
LG Kitchen Series Electric Range Smooth touch controls POSESSED!
The is a tough one if there is no tech there. I have not heard of this problem as yet. There could be a loose connection in one of the ribbon cables or it could just be a defective board.
You can try putting it in to test mode to see if it can self diagnose itself.
Press 'favourite' and 'settings' at the same time, 'diagnois' will appear, press them again and the prompts will appear. Note make sure the top surface is clear as well as the oven. If an error pops up at least you will know what is wrong with it. There is also a tech sheet on the back with the fault codes.
side note, do not put alluminium foil on the bottom of the oven cavity.
Sgt 48
