20 Most Recent Frigidaire FEF354GS Kitchen Range Questions & Answers
My range doesn’t allow me to set the time, when I enter the current time it flashes and then defaults to 2:22.
Frigidaire... | Answered on Dec 12, 2019
Hi Junior-
I found this youtube video on resetting f10 code on a gas stove.
https://www.youtube.com/watch?v=z6tcnpDKDns
Hope this helps.
Frigidaire... | Answered on Nov 28, 2019
Due to the cost of parts on this range, I would call an engineer. $310 for the oven control board, $400 for the 2 elements.
The only thing I would suggest is checking the contacts at the back of the back panel. you must have checked the element contacts when you did the continuity test. I have seen contacts get hot and snap off.
https://www.partselect.ca/Models/LGEF3045KFK/Sections/Backguard/?ModelID=6747678&ModelNum=LGEF3045KFK&mfgModelNum=&ManufactureID=4&Selected=BA2790DC09E1C5239A8B7CD13A1069F3169E482E&Position=1&mfg=Frigidaire&Type=Washer&Mark=1
Frigidaire... | Answered on Aug 13, 2019
Dear IFE KIARA,
Warning: If you feel in any way uncomfortable/unsafe performing this test or making this repair, please contact a qualified appliance repair technician.
F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
Try disconnecting power to the stove completely and flip the corresponding breaker on and off at the breaker box.
Wait 30 seconds and then turn everything back on.
if the problem persist after power-up, according to Frigidaire suggested corrective action the electronic oven control,also called EOC has to be replaced. Here is a search link from Google for the part in question.
Best of Luck,
JP
https://www.google.com/search?source=hp&ei=fecFXYCMAsKr5wKBm6G4DQ&q=316418735&oq=&gs_l=psy-ab.1.0.35i39l10.0.0..5525...1.0..0.209.209.2-1......0......gws-wiz.....10.8VUU1xaL8qM
Frigidaire... | Answered on Jun 16, 2019
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
Frigidaire... | Answered on Jun 13, 2019
As copied from the manual.
Setting a silent control panel
When choosing a function, a beep will be heard each time a pad is pressed. If desired, the control can be programmed for silent operation. Press and hold (start/time) . After 7 seconds, the control will beep once. This will block the controls from sounding when a pad is pressed. To return the sound, press and hold (start/time) again for 7 seconds until the control beeps once
NOTE!
The OVEN indicator light on the electronic display will turn ON and OFF when using the Bake feature and during preheat. This is normal and indicates that the oven is cycling to maintain the selected baking temperature. When the preheat indicator light turns OFF, your oven is ready.
Frigidaire... | Answered on Jun 05, 2019
Yes, the microwaves will still be contained,however it needs to be replaced. super glue will work if the original parts are broken or lost
Frigidaire... | Answered on Apr 25, 2019
The F50 code appears to indicate that the oven relay board can't get the status of the switches (door closed, motor door lock). Try unplugging the range to reset the control board. Next check the wiring harness. If there is nothing wrong with the wiring, then the oven relay board may be faulty.
Please add a comment with the model of the Frigidaire range if you would like a parts diagram and other information. I hope this helps.
Frigidaire... | Answered on Apr 07, 2019
Frigidaire FEF354GS Kitchen Range Logo
2 questions posted
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Kitchen Ranges
Most Popular Question
clock stay our frigidaire range oven
  • Kitchen Ranges
