20 Most Recent
Sony CDX-GT520 FM / AM Receiver Questions & Answers
Switch rear/sub
Hello guys, someone can help me ? i bought a sony cdx gt 520U , according to the manual there is a option in general settings were i can switch the SUB/REAR but i cant find it ...i got few options in general settings like Clock,CAUT ALM,BEEP,AUTO OFF,CT,BTM,ZAPPIN
Where does the remote wire
their should be a blue white wire on the back of the radio. this wire is called the amp turn on wire connecting to this wire will provided 12 volts when the xplod cdx gt520 is turned on but if you press the off button on the radio the 12 volts will drop to 0 volts but when the radio is turned on the 12 volts will come back.
No sub signal from a CDX GT520.
connect the speake(sub) directly to the stereo(just use one of the rear 6x9 speaker wire to test the sub and make sure it's not the amp. if it does not work, it's the sub
How do you switch between the front aux and the
According to the manual:
"In the case of a CD/MD changer or SAT tuner being connected: when "source" is pressed the connected device (MD, XM, or SR) will appear in the display, depending on which device is connected. Then if "MODE" is pushed you can switch the changer or change the SAT tuner band."
Sony "advertising" on LCD during operation
To remove the ad demo just press and hold the volume knob for a few seconds until the secondary menu appears.
Press the knob repeatedly to get to the "DEMO" item. Turn the knob to change from ON to OFF.
Press and hold the knob for a few seconds to exit the menus.
Can a sony cdx-gt52w be installed into a 2005 kia
I just got a mounting kit so the deck would fit. I got the mounting kit to support a 205 kia sorento lx. Then you just get a wiring harness for your vehicle and match up the wire colors on your wiring harness to the ones on the wires that came with the cd player. That's how I did it and it worked great. If you go to any best buy or car stereo place they will have most if not all your parts that you will need and also they can install it for you. But my suggestion is to try it first because I saved 70 dollars doing it my self.
Cdx-gt520 wont turn on
Pull the radio out and check the ground has a good conection. I had to run a new ground wire on one of my cars and make sure the hot lines are gitting a good curent.
Sony CDX-M850mp isnt playing any audio from aux or cd input
This issue might be due to a malfunctioning auxiliary input or a problem with the amplifier circuit. You can try the following steps to troubleshoot the issue:
- Check the connection between the auxiliary input and the head unit to make sure it's properly plugged in.
- Check the audio cable for any signs of damage or wear.
- Make sure the auxiliary input is selected as the source on the head unit.
- Check the amplifier circuit to see if it's functioning properly. If it's not, the amplifier may need to be repaired or replaced.
If these steps don't resolve the issue, it's recommended to have the unit inspected by a professional audio technician.
