20 Most Recent JVC TH-S11 Theater System Questions & Answers
0answers
3answers
Locked dvd tray.
with the unit off press and hold the stop button and the eject button.
5/18/2012 2:12:23 PM • JVC TH-S11... • Answered on May 18, 2012
JVC TH-S11 ...Shuts off after
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
6/4/2011 11:02:49 PM • JVC TH-S11... • Answered on Jun 04, 2011
The disk door cant open,
unplug for 5/10 min.........when plug back up press stop/eject
9/4/2010 5:05:57 AM • JVC TH-S11... • Answered on Sep 04, 2010
TROUBLE SHOOTING JVC DVD PLAYER DOES NOT SHOW COLOR PICTURE
Press and hole Scan Mode button for 2 seconds, Y/C will show in front display, use > to change to RGB then press OK.
3/3/2010 10:19:26 PM • JVC TH-S11... • Answered on Mar 03, 2010
The pictures are in black and white
Press and Hold The "Scan Mode" button for 2 seconds, the front display will show Y/C press > button to change to RGB then press OK. Should be back in colour.
3/3/2010 9:37:24 PM • JVC TH-S11... • Answered on Mar 03, 2010
Original Remote JVC TH S11 is not working anymore,
I found the codes:
They all start with T
The rest is EG and another T16
2/27/2010 8:14:19 AM • JVC TH-S11... • Answered on Feb 27, 2010
Does the JVC UX-A4 have aux inputs for a separate turntable to play through amp?
It does have an aux input with two levels but this isn't suitable for a turntable. A suitable input should have RIAA correction with a sensitivity of just a few millivolts for a magnetic cartridge. Instruction manual can be found on the link below... http://resources.jvc.com/Resources/00/00/90/LVT1519-001C.pdf
3/7/2024 10:42:20 AM • JVC Audio... • Answered on Mar 07, 2024
I have jvc th a75r hardret plz help
Here is the user manual; https://www.manualslib.com/products/Jvc-Th-A75r-252593.html
3/4/2024 7:47:22 AM • JVC Audio... • Answered on Mar 04, 2024
I have a JVC RX-501 reciver and 2 speakers Sony(200W). I start the reciver and After 3-4 seconds it S make a sound like" bun bun " that S all... After 1-2 minute again..
The sound you're hearing could be due to a variety of reasons, such as a loose connection, a malfunctioning component, or a power issue. Here are some steps you can take to troubleshoot the issue: Check the speaker connections: Ensure that the speaker wires are properly connected to the receiver and the speakers. Make sure that the positive and negative terminals are correctly aligned. You can also try disconnecting and reconnecting the wires to ensure a secure connection. Check the power source: Ensure that the receiver is plugged into a working power outlet and that the power cord is securely connected to the receiver. You can also try plugging the receiver into a different power outlet to see if that resolves the issue. Check the volume level: Ensure that the volume level on the receiver is not set too high. High volume levels can cause distortion and other issues. Reset the receiver: Try resetting the receiver to its default settings. To do this, turn off the receiver and unplug it from the power source. Wait for a few minutes, then plug the receiver back in and turn it on. If these suggestion don't help, you may have to seek professional repair.
2/2/2024 9:08:57 PM • JVC Audio... • Answered on Feb 02, 2024
JVC TH-S11 Theater System Logo
24 questions posted
Popular Products
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Audio Players & Recorders
Most Popular Question
trouble shooting jvc dvd player not show
  • Audio Players & Recorders
