20 Most Recent
Philips HTS 6600/12 Home Theatre System HDMI Theater System Questions & Answers
When I hook the system up. I an hear a humming or
This is the bane of all home theater installations and its called the "60 Hertz Hum" Most likely coming from your cable company.. Simple test... Disconnect any Coax cables from the outside going into your cable box or tv. Hum disappears. Most likely this is caused by a "ground loop" problem.
The solutions are far and varied. Google "ground loop hum" to find different things to try
Doesn't read disc
Glenn's answer is incomplete.
I have the same machine. I am currently experiencing a similar problem. The machine reads cd's, vcd's, but it will not read dvd's. Commercially purchased dvd's. The problem is not a format problem, not a zone problem. The dvd's work in other machines, so it is not a dvd problem. If anyone has any ideas, please respond. Thank you.
The region is 4 and would like to watch all
Try this:
Switch player on
Press eject on the remote to open tray
On the remote, press 9,9,9,9 then 0
Region:0 should appear on the screen
Switch player off, then on again
Should now be multi-region
Credit goes to rimcius from www.videohelp.com
CAN I CONVERT/CHANGE MY PHILIPS CINEMA TO TAKE
Most philips units can be easily converted (sometimes so easy you just dont want to know)
What you are going to search for is "philips region free hack" or "hts 660 region free hack"
I am unsure of FIXYA policy for providing the information directly so I gave you the words I would use to find what you want
If you are given an ISO file to download then tjis must be burned to a cd first
I agree that the region thing should be banned and customers should have the choice
