20 Most Recent
JVC GZ-HD7 HDD HD Camcorder - 60 GB Hard Drive Questions & Answers
JVC GZ-HD7 Undelete Video Files
To undelete your videos files,
the first thing you should do is STOP taking more videos with your JVC recorder.Then take more recovery programs to rescue the videos. here are some that should help you out.
For Windows --> Data Recovery Software ToolFor Mac OS X --> Video Recovery for Mac1. Connect your camera (memory card) to a PC or Mac which has installed the recovery program. 2. Scan for the lost video files. 3. Recover them easily.Caution - Do NOT try & write anything back to the recorder memory card until you can recover your files safely! Good luck and best regards!
I bought my camera at
It's JVC's choice whether to repair or replace the camera.
Possibly, for faster "turn-around", they will send you a replacement,
and _then_ "refurbish" the camera, and then try to sell it as a "refurbished" unit.
For you, that means that any recordings currently on the camera probably will be "lost",
because you'll get an "empty" 60 GB HDD inside the new camera.
Possibly, American Electronics can "archive" your recordings, before you send the camera away, and then "restore" your recordings onto the new HDD ????
WHEN I TRY TO DOWNLOAD
Described symptoms indicate that optical laser block of dvd recorder is worn out that is why dvd recorder getting fail to record or recognize dvd disc.
Put any normal dvd disc in unit to check does it playback it.
If JVC CU-VD40U is still under warranty then call numbers written on warranty documents of unit for warranty cover and if its out of warranty then new unit would be fine instead of getting it repair.
Hope these info will help you.
Thanks.
Can I stream live video from Firewire interface?
Veodia’s recently released streaming-video software is easy to use. Really easy. We’re talking plug-and-play easy. Plug your DV camera into your computer and put it in record mode. Log into Veodia.com and hit “new broadcast.” And you’re live. Instantly. And when you’re done, you hit stop and the video you’ve just streamed is available on demand through your favorite RSS feeder. Instantly. And it works.
When you hit “start broadcast” Veodia takes about 5 seconds while “detecting bandwidth.” The end product is a 320 x 240 live video feed streaming right out of your Firewire DV camera or webcam. This video is embeddable anywhere, meaning you can have this live feed be part of your blog and your viewers don’t need to be registered Veodia members. And each broadcast comes built in with a chatroom for your viewers to interact with you, the webstar, live.
Power not on or USB device not compatible
I think your battery is 100% OK, if the power supply is perfect there may be problem with the switch, clean it with contact cleaner spray often press the switch several times.
if the switch contacts are not connecting, this will help it to clear it.
open the cam, check the power supply on the main board, there is a
small fuse on the circuit board test it with. eventually we have to suspect the mother board. if so should change it.
I can not access the menu on my jvc everio gz-mz37u to reformat the hard drive and HDD error is still showing, please help.
first of all my advice is: if you keep any electronics devices without usage for a long period, you must detach the battery/power supply.
in this case I think the hard disk may be faulty, if you can open the camera and takeout the HDD connect with an HDD dock connect the dock to your system, in normal condition your computer will detect the hard disk, if so you can save the contents to your computer or you can format it, if it is not detecting your computer it means the HDD is physically damage. please change it.
Everio media browser 3 be
I solved my problem by changing the setting from PAL to NTSC in the Everio media browser (the unit was purchased in the US but the software was set to PAL).
