Thanks for the Fixya Support Call today
My examination over the phone concluded that you unplugged this unit without using the Saftly unplug incon on the taskbar witch can cause data loss, unit not to respond, or a bricked unit,
You solution today if the drive is not presenting the "click of death" take the unit out of the external case, purchase a new sata external case to usb port. You will install this into the new case.
Now if that does not prove satisifaction I would purchase if I where you Spinright
www.grc.com for $90 bucks, hook the unit to a pc desktop then run the program witch will try and recover the data off the failing drive.
If the solution proves satisfaction I would still warn you to remove the data to a safer souce before failure starts to present itself.
Hard drives last on adverage 1.5 to 2.0 years before they start to fail. I would also advice a 3 step backup plan.
1. External Hard drive or DVD's
2. Cloud backup service
www.carbonite.com3. Offsite backup with cd's or other hard drive units in a safe deposit box.
Thanks for using fixya.com I hope this call is satifactory to you.
Kind Regards,
Ed "rulds2008" Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
