20 Most Recent Frigidaire GLGH1642DS Front Load Stacked Washer / Dryer Questions & Answers
Door lock does not work
try checking it out here appliancepartspro.com or repairclinic.com have your model # sb inside the freezer compartment or frig.
1/21/2018 5:14:04 PM • Frigidaire... • Answered on Jan 21, 2018
I just changed the 220
Check the wiring legs on the machine where you put the new cord on and make sure that the wires are not touching each-other.
11/21/2010 3:42:15 AM • Frigidaire... • Answered on Nov 21, 2010
I washed a load of clothes and a narrow round
There is no spring inside the drum that may come off except for the spring and wire hoop assembly that securely holds the door seal to the outer lip of the door opening.
Check to make sure that this spring is in its proper position at the bottom of the door opening as shown in the photo above.
It will help determine what really the spring is if you can post photo of the said spring including the exact model number of the machine. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated herein.
8/8/2010 3:26:03 AM • Frigidaire... • Answered on Aug 08, 2010
How do you acsess the belt to check tension on
Remove the lower panel on the back side .
4/3/2010 3:27:31 AM • Frigidaire... • Answered on Apr 03, 2010
2answers
GLGH1642FS won't spin whites dry.
step 1- remove the face of the dryer, then remove the cover for the fan, check to see if object is blocking the fan, if object is there , remove object, if not go to step 2
step 2- check to see if the belt is broken, if the belt is broken replace the belt.
step 3 - remove the belt from the motor and turn the dryer on, if the motor doesn’t turn then you need to replace the motor.
These are the only causes.
Post further comment for more help.
Good Luck!!
Thanks
7/10/2009 7:41:00 PM • Frigidaire... • Answered on Jul 10, 2009
2answers
Glgh1462fs won't spin whites dry
turn the washer over on its side and look for a broken belt or broken direct drive coupler for the tub, this is how it spins.
7/9/2009 12:11:11 AM • Frigidaire... • Answered on Jul 09, 2009
No heat
You may have to change the heating element.
7/4/2009 1:42:19 PM • Frigidaire... • Answered on Jul 04, 2009
Dryer squeals off on during the cycle
The rear drum support must be replaced.
Part number 5303281153
4/21/2009 5:16:00 PM • Frigidaire... • Answered on Apr 21, 2009
Frigidaire Stackable Front Loader Washer
Jane, check to make sure that the drain hose has a air gap in the drain. Sometimes you will get a siphoning effect if you don't have the gap or it is pushed down to far in the drain. If this is not your problem, it's probably a timer issue...Catriver..post back
1/14/2009 5:56:59 AM • Frigidaire... • Answered on Jan 14, 2009
2answers
My Frigidaire Affinity washer makes a loud buzzing sound when you push the start button and will not start, what can I do
Good Morning Anonymous, this is Z. I am happy to assist you! I understand that your door indicates it is open and your dryer will not operate. Let's attempt resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is good to wait approximately ten minutes and turn on your dryer. Select a normal cycle and verify if your dryer will start. If your dryer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
3/20/2024 3:24:35 AM • Frigidaire... • Answered on Mar 20, 2024
Frigidaire Front Load washer (25 yrs old) fills completely but does not spin for the wash cycle. Manual timer clicks and buzzes but drum does not spin nor does the timer advance.
Sure sounds like your timer has bit the dust. I'm not sure if the timer is still available. You have a great washer there. Good luck.
2/11/2024 4:24:20 PM • Frigidaire... • Answered on Feb 11, 2024
My Frigidaire FWAC 19B5MSGNW washing machine won't move on from the spin cycle. The light is on and if I fill it up with water it will pump out the water but the spin light will not come off.
The machine does not exist as you have written it. There are two likely reasons The door switch has failed and hasn't passed the self test procedure. or the control board / timer has failed. Try power cycling it. Remove the mains plug for an hour. It is has an On Off button press it for a minute. For a knob, full it and leave two minutes. Plug back in and try again. https://www.google.com/search?q=Frigidaire+FWAC+19B5MSGNW ..
1/2/2024 11:12:23 PM • Frigidaire... • Answered on Jan 02, 2024
Frigidaire front load washer door locked
crowbar?
5/15/2023 1:33:24 PM • Frigidaire... • Answered on May 15, 2023
Frigidaire GLGH1642DS Front Load Stacked Washer / Dryer Logo
Popular Tags
21 questions posted
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
acsess belt check tension
  • Washing Machines
