Hello, I have a small (condo size) Frigidaire top
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a model MLCE52RCS1 that will, in your words, "no longer drain or spin. There is no humming or other noise at all".
First this is an unusual one...I mean the model. It is a Frigidaire, however it is built by Whirlpool...that is not very common, aside from front load washer's GE had built by Frigidaire. Many times store brands such as Kenmore, Beaumark, Viking and the like are made by large appliance manufacturer's, but it's less common for major manufacturer's to have machines built for them by other manufacturer's as is the case here.
I digress...
Based on these symptoms, I'd suggest you''ll need to check and most likely have to replace the lid switch.
Here`s how you can check it pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...it should apply to yours)
Lift the lid, if you observe the underside of the lid there will be a plastic "strike" or "actuator" that goes into a hole when the lid is closed.
Check the hole where the actuator goes into the cabinet and insure you can see a gray oval shaped piece. If so take a small screw-driver, pen/pencil or something small enough to fit thru the small hole and try activating the switch by pushing it down ( machine must be in spin cycle...advance timer to that position and turn on ). If you don't see it, the switch has likely broken loose and needs to be replaced.
If it start's to function than the switch is not being contacted properly by the actuator on the lid and likely is due to the switch being worn...unless the actuator on the lid is broke, if so there`s the problem.
Make sure the switch is being held in place via the two screws along the side, if they are loose tighten them, if it is broken, it will need to be replaced.
Let me know what you find and we can proceed from there...if necessary. As I said it is likely broke. Good luck.
Regards,
Macmarkus :)
