20 Most Recent
Discovery Channel Discovery Kids - Rocket Ship Projection Clock Questions & Answers
Discovery kids rocket clock - no manual
I can't upload a manual but I can give you instructions:1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between m/d/y/hour/minute. If it goes to the alarm setting instead of time setting, try again. 2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock3) turn on/off alarm: press "alarm set" button once, press "up" to turn alarm on and press "up" again to turn alarm off. press "time set" button to return to clock4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial under the lens-cylinders to select a different image 5) military time: press the "up" button when the time is displayed (not when you're setting the time) to change from 12 to 24 hr or vise-versaGood Luck!
7/28/2015 6:59:54 PM •
Discovery...
Answered
on Jul 28, 2015
Discovery rocket ship clock alarm off
You have to press the alarm setup, then press the up button. This turns the alarm off completely. If you want the alarm to go off again tomorrow you will have to set it again.
10/18/2014 11:12:31 AM •
Discovery...
Answered
on Oct 18, 2014
