20 Most Recent
Garmin nuvi 200W Car GPS Receiver Questions & Answers
My garmin says it is registeredon the garmin site how can i re register it
I suspect that Garmin would not allow one to re-register one's GPS as this would probably make one elligible for a map update upon said re-registration. If you did indeed just buy the garmin from a reputable dealer, you may contact Garmin and explain your situation - and they should assist you in resolving it.
Not working while in car
Hi, Get a volt meter and check the plug in the car. It should be 12.5 or more. if you don't get anything check the fuses. Check wiring as well.
Why map disapears and picture of computer&gps
It sounds like your basic operating system may have become corrupt in some manner. The picture of the GPS and computer should normally only appear when you connect your GPS to your computer. This will normally let you know that your GPS is synchronized to your computer and is ready for you to copy material over from your computer to your GPS. You can try to reset the GPS to see if that will resolve the issue. There is a reset button on the bottom of your GPS. Turn on your GPS. Then using something that does not have a sharp point, depress the reset button for several seconds, about 10-12 should do it. Your GPS should reset itself and come up with the normal loading screen. If you still have the problem then what you can do is go to the Garmin website and download and install the unit software. If you are unable to connect to your GPS with your computer as it normally would you may have to contact Garmin support to find out how you can reload your unit software.
My device won't operate while plunged in
Sometimes this is caused by a problem with the socket where the mini USB plug goes into the back of the satnav. The plug appears to be in fully but it's not. Push it in further and it may solve your problem.
If I hard reset my garmin...will this allow me to
No, doing a hard reset will NOT reset the password. There are a few methods to reset the password...
Take the unit back to your security location, make sure the antenna is up and it will automatically unlock. You can then change the password to something you remember.
If you are unable to do this for whatever reason, you will need to send the unit to Garmin with an original receipt from a Garmin authorized dealer and they will reset the password for a fee. This is a security feature that Garmin installs into the unit's main software so that the unit cannot be used if it is stolen. There is no 'master' password or reset feature for this.
Nothing Happens
press and hold the bottom right of screen, then press power button.
Touchscreen on a Garmin nuvi 1350 doesn't work
My touchscreen on Garmin nuvi 1390 not working too and .calibration it's help alsoI did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars.I didn't connect GPS to computer
My garmin nuvi says system sofeware missing
Download Garmin Express from Garmin and install to your PC. Plug your GPS into your PC, Garmin Express should identify your GPS and give you options to update maps and software.
How do I turn on my Garmin Nuvi?
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. If the GPS does not power on (it should go into usb mode), then contact Garmin for warranty work. You can also check the power adapter in your vehicle. If the red light does not come on, the adapter either has a blown fuse or went bad, causing your GPS battery to be discharged. It is quite possible that your battery is discharged. You might leave it plugged into your PC overnight if the battery is dead.
How do I fix the backlight of my garmin 3205
The LCD display contains both the display and backlight. They are integrated as one piece. Therefore the entire display needs to be replaced. The backlight connections are soldered to the LCD connections. Replace the entire display.
Call 1-8O5-225-669O GPS/GARMIN Update-Install-Download-Fix We are 24 Hour Available Call Now For Help Number
When encountering errors such as "No Map Data Available" and Garmin Express does not recognize your Garmin nuvi, check to see if your Garmin nuvi is out of storage space from your computer. Solution related to the fact that when brought up as the E: drive in windows there were 0 bytes free space on the Garmin nuvi. To get Garmin Express to recognize a unit which is full, do a search on the Windows Drive (E:) for "gmap" then choose "Open file location" This will get into the hidden ".system" directory. From there, delete the largest file map, such as "gmapprom" (or move this file to your hard drive). Afterward, reboot your computer to have Garmin Express software recognize your Garmin nuvi. On older units, also purchase a microSDHC card to be able to store the newest maps, such as the US & Canada 2.6Gb map file, which will not fit on the internal unit alone or a 2Gb card. The Garmin Express software will recognize 4Gb to 32Gb microSDHC Class 10 or UHS-I cards formatted to FAT32 and install the newest maps automatically to them. Some have reported that 4Gb cards are not large enough. I had used a 16Gb SanDisk Ultra PLUS UHS-I card ($10.88 Walmart) successfully on my Garmin nuvi 1450LMT
My garmin nuvi 2225 will not acquire satellites since I brought it to Europe. I loadd maps for the area but it can not find its position.
If the garmin can reach satellites in North America, it will reach satellites anywhere in the world as long as it has a clear line of site to the satellites. Depending where you are, the satellites can be higher or lower in the sky. This means that the garmin in your vehicle may not be able to see the satellites how you have it positioned in your vehicle. Try finding the satellites outside of your vehicle while in Europe. If you can, then the problem is positioning in your vehicle. The satellites are all the same kind no matter where you are.
Garmin nuvi 2225 will not acquire satellites in Europe. Worked fine in North America. I loaded maps for Europe but no action.
