20 Most Recent
Sharp LC-32SH12U TV Questions & Answers
After replacing the power supply board, inverter
There are so many reasons for this fault. It is difficult to include all of it here, as there is so much to type in, and to include illustrations. If
you're sound in electronics, and wish to get more details, check this
link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to
Mosaic
/ Flip card, can be selected by the
drop-down list, by the top left
of the display window, will make surf easy. You can also do a search, by type in the
brand name / model
number / IC used, in the search box at the top right of the display window. Faulty screen-shots to LCD screen are given. You can compare it to that of your TVs, and can make sure about the fault. It sounds that the main board to your TV should be troubleshooted.
google.com/+GopakumarGopalan
Sharp tv lc 32sh12u menu
Just open the menu by using the universal remote control, and do the rest by using Up/Dn & Left/Right buttons at the the TV front panel.
32sh12u screen lines
you possibly have bulged capacitors or loose connectors..or also you possibly have faulty t-con board.
Tv turns off after a few seconds and has no power
Hi, welcome to Fixya!The issue you describe is consistent with a power supply board
issue. This is the board where the AC goes to. This problem may have
occurred as a result of irregular power supply, or excess power supply
or power surge.The TV is receiving current but cannot circulate or
transfer the current to other necessary part of the TV because of the
defective power supply board. You might be lucky it's just a blow fuse.
Also a defective transformer can cause your TV not to power on.All these can be checked on the power supply board.But
more often bad capacitors causes problem on the power supply board. I
do not think the power board needs replacement, rather those defective
capacitors is causing this issue. Open unit up and take a look at the
power supply board.You will probably see one or more electrolytic filter
capacitors that are bulged up in the top-not perfectly flat like the
others.The value of these capacitors will be different, most likely
they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)You
can replace them with same values but I would recommend the voltage
rating to be higher(like 35V for an original 25V) for reliability
purposes.What happens is,these bulged top capacitors will cause a
low and unfiltered DC voltage=main board will malfunction(the relay will
keep clicking until the caps are holding enough charge to bring the
voltage up over a threshold point).You can buy these capacitors at
any Fry's or Radioshack store or you can order them online at vendors
like "mcmelectronics.com"(look for electrolytic capacitors). After
replacing these capacitor(capacitors) most likely the normal operation
will be restored. Or you can by a refurbished complete power board to
save you some stress.Note: There may be also some other causes for
this symptom ,like a defective T con board ,or main board,but the bulged
top capacitors are the most common cause for this issue.If you
don't know about TV repairers, take the TV to the nearest repairman to
fix the fault for you. Also, note that TV stores a lot of current, so
wait a while before opening the TV back cover.I hope this helps.Good luck
I have a sharp 32sh12u that has a problem where
I don't yet have a solution for this problem, As I to have the Sharp model LC 32SH12U 32 inch LCD Tv. From what I have seen and read in searching for a relatively cheaper fix than just tossing out this $600.00 Tv,I have heard T-CON Board MANY MANY times now up until today I had a guy tell me that he was pretty certain that it is the SCREEN PANEL!!! I wouldn't think that if the screen was bad it's self it would show ANY colors or tints, Lines or what have you..I just think the T-CON Board is gone bad in this Tv As it has perfect sound, And like most everyone elses for a while after my TV warmed up it would play like a champ and had a BEAUTIFUL PICTURE until now I think the T-CON Board has gone completely out on it. Sharp must have undoubtably purchased ton's of BAD T-CON Boards that fit not only this TV but also the AOC,DYNEX,INSIGNIA,And Vizio Brand's of LCD TV's...The VERY Same T-CON board which is Part Number X3562TP ,Is futted in every one of these same brands of TV's And I feel they have gone bad in Thousands of LCD TV's and it has Obviously caused thousands of people some very bad issues with their entertainment products..my wife and I are TV Folk and that is what we do...WE watch TV,,And now that our Main TV is broken and we can't really afford to just go out and Buy a new one I have to try and repair this one,And as Cheaply as I can, So I may be about to waste $40.00 on a T-CON Board, But hey I gotta KNOW..If this don't fix it, Im just gonna part the TV out on EBAY and go for another brand of TV..I thought SHARP was a really good brand of TV, But from what I have learned..our money would have been better spent on a different brand of TV!!! If this DOES repair our Tv I will be certain to come back and let everyone know!!
My LCD TV LC32SH12 U has started to show vertical
There are several processors in the tv, and it sounds as if you have one that is going out, or on its last leg. I would recommend that you take it to a tv repair shop and have it fixed. The cost of a repair is less than the cost of a new tv, thus making it worth the money.
Sharp model LC-32SH12U - 2
I don't have a solution but starting 2 weeks ago I have the exact same problem. Test different devices and cables and it points back to the TV. Anybody have a solution?
