20 Most Recent Toshiba Regza 32LV67U 32 in. LCD HDTV Questions & Answers
I REGZA 32 lcd tv, will not work for me function.when channel and press the button on the tv, it says panel lock.what problem?
read the owner manual, the book that came with the set--it is telling you the panel or front controls for the set (maybe the remote also) are locked to prevent them being used, there will be a method to unlock them in the owner manual
7/4/2020 10:00:13 PM • Toshiba Regza... • Answered on Jul 04, 2020
TOSHIBA 2010 V2.01 20100318
How to access to my tv's service menu?
4/9/2019 7:48:47 AM • Toshiba Regza... • Answered on Apr 09, 2019
My toshiba keeps jumping between source channels- any ideas
Not sure, but sounds like the problem is with the RC. Try watching TV without the RC to see if it stop jumping between channels.
7/10/2016 7:16:28 PM • Toshiba Regza... • Answered on Jul 10, 2016
Wife put another DVD in 32" Regza LCD with DVD, now 2 are stuck
Open it up. Once opened they are pretty easy to figure out.
3/26/2016 10:48:31 PM • Toshiba Regza... • Answered on Mar 26, 2016
My tv has stopped workimg
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
11/9/2015 12:54:36 AM • Toshiba Regza... • Answered on Nov 09, 2015
How much will be the cost for broken screen?
The cost for a new screen could as much as a new LCD. I would suggest to call Toshiba to inquire about the price of a new screen.
9/8/2015 9:53:10 PM • Toshiba Regza... • Answered on Sep 08, 2015
I own a Toshiba Regza 32L V67U. Screen and audio outage
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions. Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
3/8/2015 1:13:55 PM • Toshiba Regza... • Answered on Mar 08, 2015
I have a 32
3/8/2015 1:12:09 PM • Toshiba Regza... • Answered on Mar 08, 2015
MY REGZA IS SHOWING NO PICTURES,its like a radio.
3/8/2015 1:11:00 PM • Toshiba Regza... • Answered on Mar 08, 2015
Could please help me how
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
3/8/2015 1:08:43 PM • Toshiba Regza... • Answered on Mar 08, 2015
Had tv less than 4
3/8/2015 1:07:50 PM • Toshiba Regza... • Answered on Mar 08, 2015
My toshiba regza has sound
3/8/2015 1:01:01 PM • Toshiba Regza... • Answered on Mar 08, 2015
The picture comes on for a short time but the
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. or Check and replace the damaged component/s at its main board. Contact any service technician
3/8/2015 12:59:41 PM • Toshiba Regza... • Answered on Mar 08, 2015
Why do I have to keep tuning off my Regza TV at the wall socket to make it activate. When left on standby, it will not turn on until it has been disconnected and restarted.
Main power regulator board [SMPS] problem. The start voltage resistors at it should be checked. Contact any service technician. http://electronicshelponline.blogspot.com/
2/19/2015 12:55:25 PM • Toshiba Regza... • Answered on Feb 19, 2015
My Toshiba TV is stuck on channel 65535 but I can't even access the Menu, when I push the button I just get a "No Signal" message.
Try a reset to this TV and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done. 25380769-nvi2segetoqhshhqabeh4qiu-2-0.jpg 25380769-nvi2segetoqhshhqabeh4qiu-2-1.jpg
1/24/2015 3:24:37 AM • Toshiba Regza... • Answered on Jan 24, 2015
Scan for channels without a remote
Without a remote control; you can't do an auto-tune [channel scan] to this set. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
1/21/2015 12:18:00 PM • Toshiba Regza... • Answered on Jan 21, 2015
Tuner shuts off, pops, turns on, but does not tune in the channel
Check your aerial is working plug in another tv you know is tuned.
12/1/2014 1:08:24 AM • Toshiba Regza... • Answered on Dec 01, 2014
Toshiba REGZA won't play DVD. Shows "disc loading" then goes to wide screen mode, but then ejects the disc. Whats up?
Sounds like the laser pickup unit to the DVD player is faulty. Contact any service technician to replace it. The disc mechanism should be taken out of it to replace this part. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
11/17/2014 7:11:32 AM • Toshiba Regza... • Answered on Nov 17, 2014
0answers
Toshiba Regza 32LV67U 32 in. LCD HDTV Logo
154 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
REGZA Toshiba
  • REGZA Toshiba
Most Popular Question
  • Televison & Video
