20 Most Recent Toshiba REGZA 26HL47 TV Questions & Answers
What is Worng with t.v. it turns itself on then off again every 10 seconds
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
4/16/2015 3:32:24 AM • Toshiba REGZA... • Answered on Apr 16, 2015
LOST PICTURE & SOUND - UNABLE TO RE-PROGRAMME
i have a technika lcd26 207, the power button works and the light comes on, but i have no picture or no sound, just a complete blank, black screen. any suggestions please?
10/23/2012 10:30:33 AM • Toshiba REGZA... • Answered on Oct 23, 2012
I have a toshiba 26hl47 with a lighted screan but
Just bought one used on ebay. Seller said pic was ok. Has no pic but backlite when turned on. Horiz. lines at top gradually creep down. Try banging on the back and top of the cabinet and see if the pic comes in. Mine has a bad,cold solder joint on the board with the audio ckts (upper right as you face the unit. I haven't found it yet. Very frustrating,it worked for 5 days ok but came back. Curious to know if yours is the same. PS: I am an electronics eng/tech.
7/17/2012 3:24:17 PM • Toshiba REGZA... • Answered on Jul 17, 2012
I found what looks like
Miner modification design adjustment for a mass products productions fixes.99% of the LCD or plasma tvs out in sale for the consumers in the markets are never have to be upgraded or reinstall main frame firmware software at all,if u don't mess around in the main tv Tuner signal bard all.The main frame firmware software are alway and never suppose to be mess around for the tv entire life time anyway.
5/14/2011 2:20:46 AM • Toshiba REGZA... • Answered on May 14, 2011
Yellow blinking light and it
It can have bad power supply or it is detecting shorted circuits so it goes into startup/shutdown mode, thus blinking light.
Please read my guides first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on: Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series. Please post back what you find. Please leave rating if it helps.
1/8/2011 3:28:29 AM • Toshiba REGZA... • Answered on Jan 08, 2011
50hz not supported on Regza 26HL47?
You should have no problem displaying a 60hz 720 format as that is what this TV is based upon or a maximum of a 1080i 60hz picture. The TV will not support a 1080p or anything trying to feed it a 24 fps picture such as a blue ray player set for that mode. If you connected a standard video signal to a component connection on the TV, yes it will work but as you saw it will be in black and white. With the correct component connector for the Wii I believe the maximum it can be set for is 480p (DVD quality) which is much better than 480i (standard TV). If the picture is stretched out too much check the TV setting by using the FORMAT button on the Toshiba remote to change aspect ratios IE: WIDE, ZOOM, STANDARD etc..The other settings you want to check is in the Wii control panel. It probably asks you the type of television you are connected to such as 4:3 or a 16:9. You will want to set it for 16:9 wide-screen and if the setting is there you want to set it for 480p or 720p if the Wiii has that capability.
11/14/2009 5:56:27 PM • Toshiba REGZA... • Answered on Nov 14, 2009
I have a rented DVD stuck in a Toshiba 26LV46
Try unplugging the set for at least 2 minutes then trying the eject button again. If that doesn't work then you will have to take the set apart and manually extract the disc.
11/14/2009 5:47:25 PM • Toshiba REGZA... • Answered on Nov 14, 2009
Toshiba 26LV47 Bad Disk error
Probably the laser assembly is damaged. Your best bet at this point is to replace the DVD drive. If you feel like you can do it, its not that tough to do. Here is a link to a website where you can order it from...
http://www.partstore.com/Part/Toshiba/Toshiba/75005731/New.aspx
11/13/2009 7:02:25 PM • Toshiba REGZA... • Answered on Nov 13, 2009
2 dvds stuck in dvd player
TAKE THE TOP CASING OFF, (UNPLUG FIRST TAKE PLUG OUT OF THE WALL ) YOU SHOULD SEE THE DVD PLAYER CASING ON BOTH SIDES THERE SHOULD BE SOME SCREWS UNDO THEM SLOWLY, BOTH SIDES UNTILL THE COVER HAS CLEARANCE, BE CAREFUL NOT TO BANG,, TOUCH, THE DOOR EJECT SYSTEM , REMOVE 1 DVD . RETIGHTEN SCREWS (DO NOT OVER TIGHTEN THESE , ) MAKE SURE THAT DVD IN THE DRIVE SPINS FREELY. PUT CASING BACK ON , PLUG IN IT SHOULD BE FINE .
10/4/2009 2:20:07 PM • Toshiba REGZA... • Answered on Oct 04, 2009
Remote will not operate on-off
try taking the batteries out , put fresh ones in and re code , the old way put the remote in the freezer (wrap it up , and doing the above ) THAT MIGHT WORK
10/4/2009 2:11:08 PM • Toshiba REGZA... • Answered on Oct 04, 2009
I own a Toshiba 20WLT56B. The picture turned all
try cpc they have alot of spares or ebay .
10/4/2009 2:05:45 PM • Toshiba REGZA... • Answered on Oct 04, 2009
Wont turn on
another case of getting burnt out. your warentee should cover it dont worry. can be fixed.
6/30/2009 8:50:03 AM • Toshiba REGZA... • Answered on Jun 30, 2009
Can I use wireless headphones with the 42HL67US
Good wireless headphones have "line in" cable with 2 RCA plugs, which must be attached to TV's "audio out connectors. If you have only "optical" or "coaxial" audio stream out, you must upgrade your "wireless" gear to accommodate those signals. Forget about "headphone" jack! It's a blast of the past!Thanks,Alex.
12/4/2022 1:02:47 PM • Toshiba REGZA... • Answered on Dec 04, 2022
3answers
My Toshiba 75u7880az LCD tv blows the 5A fuse as soon as its plugged in!
Hi, Please immediately stop using this device and send it to Toshiba for a repair or replacement. It's not normal for a tv to blow fuses like this and could be a fire hazard. Thank you.
6/29/2022 8:27:02 AM • Toshiba REGZA... • Answered on Jun 29, 2022
3answers
Only black and white image show in my Toshiba tv
I would try sing a TV converter and a digital converter and see if that fixes the problem.
4/9/2022 1:49:55 AM • Toshiba REGZA... • Answered on Apr 09, 2022
Need to unlock side panel on Toshiba regza 42AV635DB without remote
Without a remote control, you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. All the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check these sites too. http://remotesearch.blogspot.com/ https://elektrotricks.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops; as well as online shops. Visit the sites by Desktop computer and type in the brand name of your device in the search box at the right column. It will help you find the remote you have to buy. Mobille view has no search
8/30/2021 2:38:33 PM • Toshiba REGZA... • Answered on Aug 30, 2021
TV will not turn on. IS not connected to a computer
Some people recommend trying to update the firmware via USB. Instructions here, http://hubpages.com/technology/How-to-Update-Toshiba-TV-Firmware. If it is a model 32C120U, there is a known manufacturers defect. This issue is cause by defective main board because the main processor is not well solder to the PCB or the e-prom memory lost the software data. Some time you can try replace the eprom memory on the main board (cost of the e-prom $15) or re-solder with a hot air gun the processor but 90% of the cases you have to change the main board, the cost is around $30 you can find it in www.myshoptvs.com these guy are super. To replace the main board is easy and takes not more than 25 minutes. This could be your board here, http://www.myshoptvs.com/marketplace/4169-toshiba-32c120u2-main-unit-461c4q51l11-431c4q51l11-vtv-l40613-m6662.html
3/19/2016 4:04:33 PM • Toshiba REGZA... • Answered on Mar 19, 2016
Toshiba REGZA 26HL47 TV Logo
20 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
REGZA Toshiba
  • REGZA Toshiba
Most Popular Question
worng t v turns itself off again every
  • Televison & Video
