20 Most Recent
Canon IXUS 960 IS Digital Camera Questions & Answers
My Canon camera says "Card Locked", I can't delete a picture or any other action, what can i do?
remove the memory card. Make sure the little notch on the left side is in the up position. If there is no notch, the camera will handle the card as locked. When all cards you put in the camera act the same (locked) perhaps the switch in the camera is defect. Check if the memory card slot is free of any debris. (use a magnifying glass and a strong light.
The switch on the card here is in the correct position.
Canon ixus 960 will not
I have a canon Ixus 960 IS and it will not turn on. I have charged the battery, but it still does nothing. I haven't dropped it and it hasn't been wet. Thankyou for your help
Massege apper saying card is block
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
My canon ixus 960 has water damage
As with most electronics the only possible fix is to remove the battery and keep it in a warm environment for a good while to let the electrics dry out. Sadly though the damage is usually done and condensation on the optics probably is not a good thing for taking clear pics.I would likely say you will need to replace the camera sadly :(
Can't view photos on camera screen
Hello Celia. Try going to the menu and look for the "storage" setting. Check to see if it is set on memory card or internal. Switch the setting to see if you can access the photos. If this doesn't work your 30 photos may be in a folder "type" your Canon cant access. Try moving them to a "Canon" folder that your camera created. Hopr this helps. Dale
My camera wil not start, he does nothing at all,
Before doing anything else be sure the battery is actually capable of holding a charge. Worn out batteries charge very quickly in the charger. A healthy battery will take several hours to charge.
When a "charged" worn out battery is put into the camera battery voltage drops instantly when the camera tries to start from it - nothing happens in this case.
My Canon Digital IXUS 960
Is the battery powerfull enough? Meaning has enough DC current in it to powerup? There are 2 "ON" buttons one at which the lens comes out, the second to view pictures.
Canon IXUS 960 IS had
Hello there,
Have you tried doing a power cycle? By removing the battery for 30 minutes to an hour. This will do a reset of the system.
Let me know how that goes.
Canon IXUS 960 is failure.
hi,
sorry , i must only say ..... yes
some brand of canon camera has this problem .
and this is actually depending to the chance of buyers which to get the good or bad device .
if you have supported by warranty, i recommended to return it to the relative company.
sorry
gorbesia
How do I take very
Refer to the "Magnified Close-Up Shooting (Digital Macro)" section of the manual (page 70 in my copy). If you need a manual, you can download one at
http://gdlp01.c-wss.com/gds/4/0900009924/01/PSSD950IS_IXUS960IS_CUG_EN.pdf
Be aware that you will get almost no depth of field at close distances. You also have to be careful about lighting, you don't want to cast a shadow onto the subject. Any camera motion will be magnified, so you might want to use a tripod or some other support. A good library or bookstore will have books with sections on close-up/macro shooting, as well as entire books on the subject.
Can't transfer pictures to the computer.the
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
I plug in the usb cable but nothing opens up
Try NOT connecting your camera to your computer.
