20 Most Recent
Canon Digital Rebel XTi 10.1MP Digital SLR Camera Digital Camera with EF-S 18-55mm f/3.5-5.6 Lens + B Questions & Answers
18-55mm lens lid cover
This lens takes a standard 58mm lens cap. You should be able to buy a replacement cap at just about any camera store. If you want to go online, you'll find a selection
here.
Timer
Press the Drive-Mode/Self-Timer button (on the back, near the upper-right corner of the LCD panel, marked with a one-handed clock). Select the one-handed clock, then use left/right to select a timer option. Start the self-timer by pressing the shutter button.
Lence Error in A580 Digicam-Canon
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Err 99
err 99 means there is moisture inside of the camera, probably inside the hot shoe
My connon xti 10.1 mp takes many out of focus
I think its reqiure to do the focusing adjustent or you can try to clear all camera setting from menu option four. clear both settings and try to take picture and check out of focus problem.
With my Canon EOS digital rebel xti i have the
I think it got exposure problem so need to adjsuted exposure and shutter speed or need to replace either top cover or finder unit i recommend to repaire with canon authorised centrre only.
How do you take inside photos with out a flash and
take the unit out into as bright a daylight as you can - the bottom line is you need light, hence flash or you need to take a longer exposure than you can hold - hence tripod - not having either of these means you need to get light into the speaker box
You could try household lamps and point a few at the speaker cabinet - remember to set the white balance to tungsten
also a camera lens with a good aperature F1.8 - Depth of field (focus) will not be very much at that aperture setting though
How can i print date
you can do that if you're doing direct printing (camera to printer) using the caera transfer settings, or if you want to save them to your omputer, you need to download the photos using the EOS utility (comes with the camera) and add the [date & time] stamp from the software settings
Memory card will not lock into down position. will just bounce back up
It seems that the CF reader mechanical assembly part is loose or it has out of place an internal part.
It may be caused by excessive force in pushing/pulling a CF memory card, or due to a manufacturing issueof the camera.
The solution is to open the camera, and check what is causing the problem and fix it.
If it's under warranty, I do recommend you to return it. If not, then you will need to pay for its repair, or do it yourself if you have experience, skills and patience in fixing electronic devices.
Such repair will require some philips screwdrivers, a soldering iron, soldering wire, and a st of tweezers.
There are in internet some guides to open and disassembly Canon XT 350D or Rebel 300d cameras. The disassembly process with the XTi 400D is very similar. You can Google fr such guidelines.
Best regards,
Canon rebel xti digital camera mem. card will not lock into place
It seems that the CF reader mechanical assembly part has loose or out of place an internal part.
Best regards,
