20 Most Recent
Kodak EasyShare C713 Digital Camera Questions & Answers
Message when turning camera on "Internal memory is full"
check for extra drive in My Computer. ...you should be able to see extra connections....explore those connections..if you see your camera pictures in it then you are connected to your camera...simply cut and paste them into your desktop or pic folder and files will be deleted from your camera...and this your internal memory will again be yours...:)
Fuzzy lines like interference on screen and then
you\'ll need a donor camera, and to replace the lens mechanism is easiest..... the ccd is screwed on the back as part of the mech but worse case cenario is that you would have to swap the ccd\'s if the swapped lens mech was broke.the ccd is basically an elecronic retina (as in "eye", not display)
PRINT INSTRUCTION MANUAL
You may download a printable user manual
here. If you don't want to print and bind it yourself (and I wouldn't blame you if you didn't), most office supply stores and printshops should be able to do it for you.
I replaced batteries and it
To isolate whether the problem is the battery or the camera, first, make sure that the battery you have is rechargeable and fully charged. Most NiMH batteries purchased for this cameras needs to be charged first. If that doesn't turn on the camera and you have a docking station for it, you might want to plug the camera dock, remove the battery from your camera, place the camera on the dock then turn it on. If the camera turns on, it means that the problem is only with the batteries, if not, it means there is something wrong with the camera hardware itself. You might want to contact Kodak technical support for that so they can take note of the problem, they may try to troubleshoot some more, but if that still doesn't work and the camera is still under warranty, you can have it arranged for repair.
Cant put in thesd card
Hello Gage, The SD memory card only installs one way. If there is a problem with the card going all the way down then the contacts in the camera are damaged.Best Regards, Russell
I have deleted photos from m763 camera and need
you can
recover deleted photos from camera with camera recovery software1. Remove the memory card from camera and connect SD card to computer with a card reader. You should see memory card shown as a drive letter (like H:) in My Computer.3. Download recovery software, recommended one is this photo recovery (simply because i was using it and it worked)
http://www.asoftech.com/apr/4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
About self photos?
Press the Menu button, use up/down to select "Self-timer," choose an option, then press OK. Start the self-timer by pressing the shutter release button as usual.
Computer will not regognise camera
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
