20 Most Recent Canon PowerShot SD950 IS Digital Camera Questions & Answers
My lens will not close
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
9/26/2011 2:01:59 AM • Canon PowerShot... • Answered on Sep 26, 2011
2answers
6/18/11 My Canon Powershot SD950 IS
Hi, It sounds there's faulty wiring in there which can develop over time in photos. Since tapping on it fixes the problem it'd likely be fixable however fixing anything in a point and shoot camera tends to be costly. If you're wanting to keep the camera you could likely have it assessed at a local camera repair shop or by sending it off to Canon. If you need more help let me know =)
6/19/2011 7:15:24 PM • Canon PowerShot... • Answered on Jun 19, 2011
Memory card error
Make sure your camera can take San Disk. It probably takes a certian card or the SD card might be upside down. Some brand and models stay this fault and the problem with the SD is that it does not accept a memory card higher than 1GB. This info isn't in the user guide. Have you tried an external usb card reader?
Pull the card out and re-insert. the most likely problem is the card was not seated properly in the slot.
Keep us updated.
5/28/2011 10:49:27 PM • Canon PowerShot... • Answered on May 28, 2011
2answers
Have sd 95. When I erase photos a hand sign comes
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
3/12/2011 8:17:23 PM • Canon PowerShot... • Answered on Mar 12, 2011
Why my camera stop working the lenses not
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
2/24/2011 10:43:25 PM • Canon PowerShot... • Answered on Feb 24, 2011
2answers
The lenses on my sd 950 is stuck and whenever i
Please try out this one. It's proven to fix what you are currently experiencing now. But we take no responsibility if ever camera got worse. Anyway, what you can do is you can try to let the camera face down, while turning it on, tap it gently onto your palm. Apply a little force. If it still does not work for the first time, try to do it again until you get the right timing. But if all else fails, to avoid further problems on the device, you would have to consult Canon to fix the issue.
1/4/2011 4:41:14 PM • Canon PowerShot... • Answered on Jan 04, 2011
My Canon SD950is camera asks
Yes I get something similar with my Panasonic camera just because I take the battery out when the camera is waiting for the next outing, but it is ok as soon as I set the clock and if I leave the battery in. From what you said then perhaps the internal battery is faulty but if you don't usually leave the battery in, you could try leaving the battery in for a few days to see if that restores some power to the internal battery.
12/12/2010 8:56:01 PM • Canon PowerShot... • Answered on Dec 12, 2010
0answers
2answers
I droped my canon sd 950 is digital elph
it is because your lens has been stucked so please give it to a service centre
12/2/2010 5:29:06 PM • Canon PowerShot... • Answered on Dec 02, 2010
I can't transfer my pictures
Please install the latest driver.This will solve the problem.
You can download the driver from below website
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd950_is#DriversAndSoftware
Thank You
10/4/2010 6:39:24 AM • Canon PowerShot... • Answered on Oct 04, 2010
Canon PowerShot SD950 IS lense won't retract
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/30/2010 7:26:31 AM • Canon PowerShot... • Answered on Sep 30, 2010
I can't turn on the camera, even with a fully charged battery.
The battery contacts are like little springs, as the camera gets jostled these can stop making good contact. Open the battery case and try force holding the battery against the contacts (You may need to hold a piece of metal across the bottom of the battery as you push) Then see if the camera comes on.
If it does, you may have to stuff, pull, or rig the battery to fit more securely.
9/20/2010 4:53:39 AM • Canon PowerShot... • Answered on Sep 20, 2010
Sd950 is has a lense
Hello
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/12/2010 9:36:56 PM • Canon PowerShot... • Answered on Sep 12, 2010
My Powershot SD950 IS will not turn on. When I
Hello Chris
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Andrea
9/2/2010 4:29:04 AM • Canon PowerShot... • Answered on Sep 02, 2010
How do remove
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
7/30/2010 4:22:39 PM • Canon PowerShot... • Answered on Jul 30, 2010
Canon PowerShot SD950 IS Digital Camera Logo
56 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
lenses sd 950 stuck whenever
  • Cameras
