20 Most Recent
HP Compaq Presario SR5210NX Desktop PC Intel Celeron Processor 420, 1 GB RAM, 120 GB Hard Drive, Vista Questions & Answers
Video wont show
This would be caused by several things.1) bad power supply causing the computer not to start2) bad video card3) bad monitor (does the monitor light come on?)4) other component bad--disconnect them all except the CPU, memory, and video card and see if you get an image.
2/28/2012 11:34:34 PM •
HP Compaq...
Answered
on Feb 28, 2012
Video wont show
HiIs your monitor on?Then check the VGA [cable from the CPU to the Monitor] connections.Try replacing the cable and see what happens.
2/28/2012 7:49:29 PM •
HP Compaq...
Answered
on Feb 28, 2012
Bios password reset
to reset the bios password you will need to remove the cmos battery from your computer. open your computer and locate the cmos battery. it looks like the size of a nickel. make sure your computer is powered off and unplugged.
2/16/2012 9:09:23 PM •
HP Compaq...
Answered
on Feb 16, 2012
I have bought new boot disc or restore disc but it
for setup the bios usually by pressing delete at first screen appear
or for some type motherboard is pressing F2 at first screen appear
after you at setup bios go to boot menu
the go to select boot menu and chose boot from cd for the first boot
then press f10 to save the bios setting and computer will restart
after restart isert your boot disc and if it ask to press any key to boot from cd press any key
then follow the instruction for install the operating system
3/4/2011 2:29:09 PM •
HP Compaq...
Answered
on Mar 04, 2011
Computer is slow.
I would start by booting into safemode with networking and then download and install
Malwarebytes to check your computer for any unauthorized programs running in the background.
8/25/2010 3:34:58 PM •
HP Compaq...
Answered
on Aug 25, 2010
Installed a new hp printer. Now evrything runs
go to START, RUN and type "MSCONFIG" Then after the windows pops up at the top there are tabs. Click on the STARTUP tab, Find your printer software in the startup tab and uncheck it and click apply. This will stop your printer software from starting up every single time you computer boots up, This will not stop you from being able to print only from the software from running from the startup. Some printer software may have to be re-opened when your ready to print but not with most.
11/11/2009 2:21:56 AM •
HP Compaq...
Answered
on Nov 11, 2009
Restored computer now my speakers don't work
You may need to access your control panel, classic view, system, device manager, and then click on sound devices,
right click on each device listed there and click update driver..
10/30/2009 4:16:29 AM •
HP Compaq...
Answered
on Oct 30, 2009
Compac presario CQ62
Hello
Most laptop or PCs, has a combination keyboard pressing keys, that invoque the restore routine.
usually F11 or F10.
others has DVD, check and see what you have of these two.
in the first one, you recover from a disk partition the whole OS.
Bios update fore presario 8000
Its all about go to HP page, and bios updates, the instructions are there too!
but be aware you have to be more specific on model, and BIOS dates.
