20 Most Recent Brother HL4040CN Laser Printer Questions & Answers
2answers
3b error code on display unable to print
Sorry, this is a serious error and it means the PC board is toast. On mine, it gets to 22 on the counter (I assume it's a RAM integrity check) and then the LCD turns red and says "Print Unable 3B". When I called Brother they told me I needed a new PC board, which by the way is very hard to get to (you have to disassemble everything, then take apart the printer piece by piece). The price for the PC board is around $100 plus labor, so you're talking easily $200 to fix this.
Thanks Brother for making a self-destructing Lemon of a printer, the Brother HL-4040. And thanks for telling me I was on my own and to fix it a local repair shop.
11/14/2021 7:43:57 AM • Brother HL4040CN... • Answered on Nov 14, 2021
2answers
Drum error. slide green tab in each color - Brother HL4040CN Laser Printer
Try removing all the toner carts and remove the drum unit from the printer. Using the upholstery tool on your home vacuum cleaner, clean all over the drum unit being careful not to directly touch the drum surfaces (they scratch very easily causing permanent marks to print) also vacuum out the inside of the printer. It is likely that dust is preventing correct charge build on the drum. Also make sure the green slide tabs are placed back at the home position at the side of the drum unit. Re-assemble and test.
7/30/2021 11:42:04 AM • Brother HL4040CN... • Answered on Jul 30, 2021
2answers
What is code 71 on
Steps to troubleshoot the Brother Printer Error Code 71 Step 1:Verify the firmware rendition To guarantee the Brother machine is dealing with the ideal settings it is prescribed the machine to have most recent firmware Press * and # keys at same time on numeric key cushion of the machine board When a few letter and number presentation top line of the LCD, in the event that it is P or higher than it is fine form to be utilized or if the firmware rendition is N or lower you have to refresh When the update is finished move to subsequent stage Step 2:Turn off the Brother Machine power switch and after that walk out on Stage 3: Print the User Settings by squeezing MENU, 6 (Print Reports), 4 (User Settings), START. On the off chance that the User Settings are printed accurately and the mistake won't return, and the issue has been settled. .If facing any problem related to a printer please visit us Brother Printer Error Code 71.
10/7/2019 7:24:02 AM • Brother HL4040CN... • Answered on Oct 07, 2019
3answers
1. power down the printer.
2. remove all color cartridges from their slots.
3. inside the color slot, you will see a green slide that will not move until you pick up the plastic cover.
4. rotate the plastic cover forward.
5. slide the green slide 3 or 4 times. (DO NOT TOUCH SMALL WIRES!)
6. return slide to original position.
7. snap the plastic cover back in place
8. return each color cartridge to it's slot.
9. replace color cartridge holder back to printer.
10. close all covers
11. turn printer back on.
If you still get the "move green slide" error, just repeat these steps
This took me about 10 minutes for the process, after understanding what the "green slide" meant.
12/20/2018 11:49:08 AM • Brother HL4040CN... • Answered on Dec 20, 2018
2answers
I get error message Print Unable E1 for my brother
E1 is called a program error, asking the printer to do something it thinks it can't. Could just be a print that uses a lot of memory, if you don't have the extra memory installed. The manual just says to power off and on again, but I would also look at what you are trying to print and try another job.
2/12/2018 10:03:22 AM • Brother HL4040CN... • Answered on Feb 12, 2018
Brother HL4040-CDN prints washed out and wrong color
That is a cartridge issue.
7/13/2017 10:12:32 PM • Brother HL4040CN... • Answered on Jul 13, 2017
0answers
Why is my printer coming up Print unable 21?
Brother HL 4040CN User Manual install relevant printer driver for the OS
9/20/2016 12:02:37 PM • Brother HL4040CN... • Answered on Sep 20, 2016
0answers
Printed paper has a red line on one side of paper
toner drum is faulty replace it
5/9/2015 4:49:55 PM • Brother HL4040CN... • Answered on May 09, 2015
0answers
Hl4040cn will not print test page
Try doing a machine self test to ensure that it is working properly. Press OK/return to "Machine Info" Then down arrow once to "Test Print" and OK/Return. The machine should produce a self test printout. If the machine does not give a print out, try cleaning the paper pick up rollers at the back of the paper tray cavity. Be careful, the machine is heavy. If a full test print happens - Your printer is working fine and the problem is at the computer end. It's possible driver installion is faulty or incomplete and you should try re-installing the printer driver. Is it also possible that your printer paper settings are either incorrect or do not match the paper in the printer. Check and match your paper settings in the printer preferences and the paper tray.
11/8/2013 4:17:36 AM • Brother HL4040CN... • Answered on Nov 08, 2013
Magenta toner does not print, printer says its
Take the toner cartridge out and try to turn the Developer roller ( the toner coated roller), if it doesn't turn you have a faulty cartridge. If the cartridge is OK, recheck the Magenta drum to see if the thin corona wire has been broken. You will need to remove the Cyan toners to get to the corona wire cover. If is damaged or broken, the whole drum will have to be replaced.
11/5/2013 10:48:31 PM • Brother HL4040CN... • Answered on Nov 05, 2013
Brother HL4040CN Laser Printer Logo
113 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
HL Brother
  • HL Brother
Most Popular Question
code 71
  • Office Equipment & Supplies
