20 Most Recent Dopod D810 Smartphone Questions & Answers
Greetings. The dopod d810's below-screen
w40 is not a good thing to use it leaves an oily residue on stuff that's way its used to clean and remove rust and lubricate rusted nuts. you now need to remove all the wd40 from the device. should only use electrical switch cleaner as it cleans and evaporates. when clean it may work again but there is no telling if it has damaged anything. screens don't like grease inside them. try spraying cheap deodorant on it sometimes it will remove the grease but remove the battery .
2/20/2018 3:38:28 AM • Dopod D810... • Answered on Feb 20, 2018
I want to change the
As it use Windows Mobile, you need to download english ROM from HTC website. Cnat post the direct link so on google, search for Dopod D810 english language rom and the second link was for download.
4/11/2011 3:25:39 PM • Dopod D810... • Answered on Apr 11, 2011
Greetings. The dopod 810's below-screen
you disassemble your device before you spry wd40.. if not you much open your unit because there some lick over the connection of touchscreen connector... you much clean by soft brush...
3/24/2011 10:11:59 AM • Dopod D810... • Answered on Mar 24, 2011
Cracked touch screen and the
Hi, your screen needs to be replaced and it can be done by any third party repair service around you because of the complicity involved. That is any mobile phone repair tech can fix it for you
2/28/2011 7:36:02 PM • Dopod D810... • Answered on Feb 28, 2011
Hi How i can unlock my dopod810
To unlock your phone from security code, follow the information from this link.
To unlock your phone from network lock, follow the information from this link.
2/28/2011 10:44:15 AM • Dopod D810... • Answered on Feb 28, 2011
I have placed a micorsd (inside mini sd adapter)
HAve you inserted it in the right manner, if not remove and put it correct.
If not the micro card may have a contact issue with the slot in the phone. remove and insert or try this card with a phone or to your laptop with the adaptor. If faulty change as some brands have problems of contact or storage detection.
If the card works fine look into the slot use a jet of air to dispel any dirt in the slot. If not remove the cover and try to clean if not the slot reader contacts are faulty.
Please rate my comments
9/2/2010 7:14:19 AM • Dopod D810... • Answered on Sep 02, 2010
2answers
Pcsuit
Download and install Activesync into your pc. You can download it free at http://www.pocketpc-freeware.net/dopod-d810-device-594/activesync-download-240.html
4/11/2010 1:15:26 PM • Dopod D810... • Answered on Apr 11, 2010
How to install themes in the mobile phone
Hello :
Ok, if i understand you correctly you want to download new themes for your phone?
At the link below you will be able to find new themes and download it free of charge. just look around in the page and you will find what you are looking for .
http://www.mobile88.com
Hope this can help.
rate this please
1/31/2010 10:04:48 PM • Dopod D810... • Answered on Jan 31, 2010
I want to hard reset it
send me how to hard reset dopod d810
1/20/2010 4:25:04 PM • Dopod D810... • Answered on Jan 20, 2010
2answers
BLUETOOTH! HELP
Go to the start menu, and select Settings. Select Connections from the bottom tabs and find the Bluetooth icon, and click on the bluetooth icon. Select Mode from the bottom tabs and check box that says "turn bluettoth on"
1/2/2010 10:29:38 PM • Dopod D810... • Answered on Jan 02, 2010
Serial number
All phones have their Serial Numbers (IMEI Number) just below the battery. You can also get it on screen by dialing *#06#.
12/10/2009 4:11:00 PM • Dopod D810... • Answered on Dec 10, 2009
Phone Crashes multiple times per day. Resets to 01/01/2007 date.
HI FRIEND...
I THINK u may have more applications open or too much RAM consuming,,,uninstall some off them..or format ur phone once thats all..
thank u..please rate it
11/12/2009 1:18:27 AM • Dopod D810... • Answered on Nov 12, 2009
Transfered memory to a storage card.
you could try a hard reset (It will delete everything like files/contacts etc thought)
Hard Reset
press and hold the left and right soft keys together and at the same time, use the stylus to press the RESET button at the bottom of your device. You will be presented with a menu saying 'press SEND to restore factory default, press END to exit', if you press SEND Your device will be set back to factory default settings.than Press "OK" to boot...
3/23/2009 2:58:06 AM • Dopod D810... • Answered on Mar 23, 2009
GPS receiver not functioning
you may can go www.xda-devlopers.com search from there.
12/29/2008 9:59:35 AM • Dopod D810... • Answered on Dec 29, 2008
2answers
My dopod d180 is stuck on a screen which says "Press resend ..."
Try keeping the start button pressed for few seconds, after the unit shutdown, restart it.
12/28/2008 12:49:40 PM • Dopod D810... • Answered on Dec 28, 2008
Shortcut to bluetooth
Go to "Start" --> "Settings" --> "Today", click on "Items" and choose "HTCHomeplug". "Comm Manager" is in the "HTCHomeplug".
10/5/2008 5:24:52 PM • Dopod D810... • Answered on Oct 05, 2008
I want to change my dopod d600 to English,how will I do it pls
Do a hard reset if that doesn't work then you will have to download software.
8/7/2016 12:58:20 PM • Dopod Computers... • Answered on Aug 07, 2016
Why wifi will not find signal it was working while i was on it and nothing now ?
reboot the item then try to find the signal
8/6/2014 11:38:33 PM • Dopod Computers... • Answered on Aug 06, 2014
Dopod D810 Smartphone Logo
Popular Tags
27 questions posted
Popular Products
Top Dopod Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Dopod Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Dopod Computers & Internet
Most Popular Question
want change
  • Computers & Internet
