20 Most Recent
O2 Xda Atom Exec Smartphone Questions & Answers
Saya punya o2 xda atom
hp saya o2 eda atom exec kok ime not ready bagamana biar normal bwt para master o2 please kasih bantu trim dan moga jadi amal
I have a xda exec phone .the screen is blank with a serial up and 1.0v down the screen .. pls tell me what to do ..
Your phone is in bootloader mode. If you have not intentionally put it in that state, it might have entered it after an usucessful ROM upgrading process. Anyway, to get out of that state, just soft reset your device. The reset pin is located at the left side (in portrait mode, or at the back of the phone, when its screen is slided open). Just lightly press that pin with the stylus pen.Hope it works for you.Anyway, please, let me know if you need further informations.Regards,Carlos
Changing the code on standleford es20 safe
If the problem is that the safe is not accepting your pin code, try first code 159A, or 159B that are default codes to open the safe.
If you have the sentry key, open with key, and there is a red button inside the door to reset the
code.
If you have no key and default code does not work, call sandleford number at 03 97750699 they will guide in opening the safe.
I want to align My
Hi!
To align the screen use these steps:
1. Tap Start > Settings > System tab > Screen.
2. On the General tab, tap Align Screen, and follow the instructions on the screen.
GoodLuck!
eBookBoy
My Phone does not switch on.
Perform a hard-reset.
At the expense of your data-loss,
atleast you get your device working back.
To perform a hard-reset on your O2 Xda Atom,
Keep pressed the POWER key, and then perform soft reset. After the device this leave everything and confirm that you want to hard-reset as shown on the screen.
Please rate...
Salam sejahtera buat master.nih mau
Halo P' Giarto, Salam sejahtera,
Bapak pake operator apa? Biasanya tiap operator memakai kebiasaan buruk sendiri2 ( membuat set up yang berbeda beda satu dgn lainnya).
Di Indonesia sebaiknya bapak ke kantor cabang operator saja, suruh dia setting dan bapak tinggal nunggu saja. Biasanya akan butuh penyettingan user name, password( kadang ini gak ada), Proxy dsb.
Utk + perbendaharaan bapak bisa lihat links dibawah ini:
www.cnet.com.au/o2-xda-atom-exec-240063806.htm
www.fixya.com/tags/o2_gprs
GBU, hrp divot, Jaya
