20 Most Recent
JVC Everio GZ-HD3 Flash Media Camcorder Questions & Answers
If you plug in the USB cable from the camera to a Windows XP machine, the Everio disk looks like a USB disk drive, and I can copy the files over using Windows Explorer. In order to convert them to MPG files, we are using Cyberlink PowerDirector5 NE Express, since the camera produces TOD files, which need to be converted to MPG. We are using MAGIX as the video editor after the conversion from TOD to MPG.
[email protected]
I have a JVC GZ-HD3
This one has a standard mini-jack mic input.
let me know if you need further assistance
thanks
Kevin
Everio GZ-HD3U
yes where could i download a free downloaded manual of JVC EVERIO GZ-HD3U.... tnx
Power not on or USB device not compatible
I think your battery is 100% OK, if the power supply is perfect there may be problem with the switch, clean it with contact cleaner spray often press the switch several times.
if the switch contacts are not connecting, this will help it to clear it.
open the cam, check the power supply on the main board, there is a
small fuse on the circuit board test it with. eventually we have to suspect the mother board. if so should change it.
I can not access the menu on my jvc everio gz-mz37u to reformat the hard drive and HDD error is still showing, please help.
first of all my advice is: if you keep any electronics devices without usage for a long period, you must detach the battery/power supply.
in this case I think the hard disk may be faulty, if you can open the camera and takeout the HDD connect with an HDD dock connect the dock to your system, in normal condition your computer will detect the hard disk, if so you can save the contents to your computer or you can format it, if it is not detecting your computer it means the HDD is physically damage. please change it.
Everio media browser 3 be
I solved my problem by changing the setting from PAL to NTSC in the Everio media browser (the unit was purchased in the US but the software was set to PAL).
