20 Most Recent
Sony DCR-DVD91E DVD Camcorder Questions & Answers
Discs will not play back on dvd
What DVD's are you using +R/RW -R/RW some formats may not work especially on non-branded media some DVD players wont even play CD-R but will play some CD-RW of the correct brand.
I suggest that you try your finalized DVD in your PC then create an image using
ImageBurn then burn the image onto a branded media and try again. Most firmware on DVD burners are very forgiving and will support a wider range of manufacturers and formats.
Hope this helps, you might want to look on your DVD players website for updated firmware you will need a blank CD and create a update disc using your computer.
How do I clean a Dyson DC 23 so it will pass quarantine inspection when moving overseas (to New Zealand)
you will to ontact the customs office in Kiwiland for that answer. In most cases cleaning the hopper in warm soapy water and buying new filters is enough. Some places require a hospital grade detergent such as wESCODYNE be used to include the air hose(s). Please beware, the AC power in AU/NZ is 230 VAC, so you will need a step down power transformer to use it there. (You'd be better off just buying a new one there to be honest, then you needed worry about lugging a heavy power transformer around of changing the plug end to the Clipsal type used in AU/NZ.)
