20 Most Recent
JVC GR-DV800U Camcorder Questions & Answers
Manual please
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Lcd screen on my gr-dv800
Usually screen replacement is not economical to repair. The part is usually around 110-140 dollars. If you have older tapes this is the only way to play them back. You could go to jvc.com to have a flat rate repair calculated. Hope this helps.
Jvc gr-dv800u blinking power light
The camera's battery is charging while the light blinks. When the battery gets fully charged, the led will stay on, indicating that the battery is charged. The manual should explain this, in case you still have it. Good luck, and hope this helps.
I can't download video from videocam to pc.
You should be able to connect your camcorder to IEEE1394 socket on a computer, by means of a firewire cable, and capture the video with Windows Movie Maker or other software. Windows Movie Maker is part of WindowsXP and is already instaleed on PCs.
Canon ZR-800 Mini DV Camcorder tape stuck
The way I can get a tape unjammed on my Sony camera is to remove the
battery, plug the camera into the AC charger that is plugged into the
wall outlet. Then power the camera on, wait a few seconds. Then unplug
the charger from the outlet, wait a few more seconds (camera still in
"on" position) and then plug it back in. I have used this method at
least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
