20 Most Recent
Infinity Reference 5350a Car Audio Amplifier Questions & Answers
How do you reset the
Most car audio amplifiers don't have on off switches.
So to reset the amplifier, disconnect it from the power source, from the car battery side.
Disconnect the positive side (red) first. Then the negative side (black)
Or sometimes its easier to remove the fuse next to the battery for the amplifier.
After its disconnected leave it disconnected for approx 5-10 min.
I hope this helps
MobileJB
7/13/2011 2:10:45 PM •
Infinity...
Answered
on Jul 13, 2011
My amp is suddenly going
I would take it back to where you purchased the amp. As it should have limited one year warranty! At least it is worth a try.
9/21/2010 2:37:32 AM •
Infinity...
Answered
on Sep 21, 2010
Firewall access
Drivers side under the break booster. Should be a rubber grommet, but if not it is safe to drill there.
8/23/2009 8:27:16 PM •
Infinity...
Answered
on Aug 23, 2009
Losing power
After reviewing the owners manual I can only guess that your amp is faulty and will need service. There is no reason for the power and protect lights to both be off while the power and remote wires are active. I'm assuming of course that power is still applied and remote is activated. It's difficult to diagnose problems online without voltmeter readings but my bet is on a faulty amp. In this case it will need to be professionally serviced. Before paying for service you could check the voltage at the 12V and Remote terminals, both should be 12volts. A solid ground is obviously required but it sounds like you have wiring covered. Feel free to post any updates and I'll continue to provide options if I can.
9/28/2008 3:43:55 PM •
Infinity...
Answered
on Sep 28, 2008
What is the wiring schematics for an Infinity Gold Amplifier 56007499?
hi,
if thats a dodge this might be it..
Re: Infinity Gold AMP Wire Diagram
Well I don't particularly care for
Haynes manuals, but my FSM's did not have anything either. I found this in thejeep cherokee haynes manual and it says that it is for 97 and later models but see if it is close. it looks like there are 2 harnesses so I will list them seperately:
Hartness 1:
[7] Left Soundbar Speaker (+) BR/YL
[8] Left Soundbar Speaker (-) BR/LB
[5] Left Front Door Spkr (+) DG
[1] Left Front Door Spkr (-) BR/RD
[9] Right Soundbar Speaker (+) DB/WT
[3] Right Soundbar Speaker (-) DB/OR
[6] Right Front Door Spkr (+) VT
[2] Right Front Door Spkr (-) DB/RD
[4] Power Amp Relay Feed DG/RD
Harness 2:
[05] Right Soundbar Spkr (+) TN/RD
[13] Right Soundbar Spkr (-) TN/BK
[06] Left Soundbar Spkr (+) WT/TN
[14] Left Soundbar Spkr (-) WT/BK
[11] Passenger Door Spkr (+) LB/RD
[10] Passenger Door Spkr (-) LB/BK
[04] Drivers Door Spkr (+) DG
[12] Drivers Door Spkr (-) LG/RD
[01] Power Amp Feed
[02] Power Amp Feed
[07] Power Amp Ground
[08] Power Amp Ground
The tweeters run in parallel off of the door speakers.... If I can help any more let me know.
-Mike.
https://forums.off-road.com/jeep-mid-sized/105694-infinity-gold-amp-wire-diagram.html
