20 Most Recent
Panasonic Lumix DMC-FZ18K Digital Camera Questions & Answers
Importing movie onto PC with Vista
I think you should install a software program that has the capability of opening mov file. This would become a plug-in for other programs and enable them to interpret it as mov file. or click on your movie file from camera and change its properties to be opened by a certain software that can open mov file and use it as the default program to open that file.
Cant download pics from camera
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa:
Organize edit and share your photos
I have a panasonic Lumix
Your card is probably good. Go into the camera's setup menu and find the picture storage or memory section. Select external memory as default and you should be good to go.
How can i fix it
Pull the memory car out of the camera, on the left side (label side) of the card is a tiny slider switch, it says "LOCK, made sure the slider is not in the lock position which is down, if the slider is not in the lock position then the memory card is defective.
I can see all the
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
How do I format my
Turn on camera, put camera in viewing picture mode. press menu/set, navigate to setup. on page 4 of setup, you have an option to format your memory card.
Error message saying remove lens cap
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
