20 Most Recent
Aiptek DV8800 Digital Camera Questions & Answers
Hi.
A while ago i purchased
The output from most computer USB sockets is insufficient to charge any camera, but replacement wall plugs are easily obtained.
How do I charge my
In most of this kind of devices, the USB data transfer cable also charges the battery of the portable device when connected to a computer or a laptop. They can be also charged with a wall adapter with compatible USB connector on it.
AIPTEK Dv8800 Driver malfunction? Answer
- aiptek web site has a driver solution for vista users I had same problem but with Win XP it keep seeing it as a flash drive .... I uninstalled drivers and re-installed them,- same error, then uninstalled again and removed the USB from device manager uninstalled direct X cause it was the newest version, then install everything from scratch without turning the camera on then try again and nothing, finally I turn to the manual and somewhere says "if you need to use it as web cam then press the menu button on the camera and select camara!!! as soon as I did that and additional port found in windows was detected and installed automatically then I got my video and microfono up and running. So easy right, but like always the software CD is missing the manuals too and people do not read. LOL .....
File failed
Mine is freezing up as well and then the file filed...help!
My aiptek dv8800
Have you tried a new memory card? It might have been damaged, when it was jammed.
Help
i have this exact same problem!!!
my camera won't download the MP3
files! it just says "no file" after i
upload{or try to} music from my
computer!
Blue screen only
If you are nearby a Best Buy store they can look at it.
Does it change when the batteries are reinserted?
Charging
You charge it by plugging into the usb plug on the camera. When you purchased the camera there should have been 2 cords that came with it. A usb plug to your computer, and a usb plug to plug into an outlet. Both will charge your battery. You should be able to purchase a usb to computer cord at a Circut City or other electronics store. Just make sure you take the camera to the store with you. To make sure you get the correct cord.
Dv8800 aiptek
You have to have device drivers loaded to use as a web camera. If you go into my computer does it see your computer as a web camera as well as a storage device?
Recorfing tv
Sure.
The yellow and white wires you have are called RCA connectors. There aka media cables too. You should have male ends that can connect to the output of your TV by matching the colors.
I just need to need to know what kind of connects you have on you camera to record the TV signals with.
HELP
is it only on the videos or is there no sound on voice either?
Sound
ttry turnign up the volume. when you start a video clip hold the joy stick up and the volume increases. you mighthave yours on zero
Camera
um no that goes into your wall socket
Night video
the light on the front is only a flash bulb. if you want to record at night use "night shot plus"
Webcam
With the camera focus away from press the left curved button to record video. To use as a webcam hook the usb cable to your computer, and open the software that came with your computer. Press that same button and in the software you will see the webcam. Or you can use your chat program to access the webcam.
