20 Most Recent LG LDF9810ST Built-in Dishwasher Questions & Answers
2answers
LG dishwasher leaking out the bottom of the door.
My dishwasher was doing the same thing, but it was because of a clogged vent. The minerals in the water built up to a point that it was totally blocked and since it couldnt vent, the water ran down the inside of the door and leaked out the bottom. I just popped the vent cover off of the inside of the door and cleaned it out and it stopped leaking.
3/17/2021 5:43:35 PM • LG LDF9810ST... • Answered on Mar 17, 2021
0answers
I have a prima LPR 450 dishwasher, the light is on but I cannot select a program
If the unit is not operating, then it will require service. To make service arrangements, you may either contact our Customer Interactive Center at 800-243-0000, or you can check our Repair Provider Lookup on our website, at http://www.lg.com/us/support/repair
5/10/2014 6:13:22 AM • LG LDF9810ST... • Answered on May 10, 2014
Water not draining and a e0 is flashing
http://www.fixya.com/answer/answerpageslideview.aspx?thid=24072807&ctg=131&brd=474
5/2/2014 1:38:15 AM • LG LDF9810ST... • Answered on May 02, 2014
Hi, I bought a second hand prima lpr 450
Hi, thanks for your help. We have solved the problem and the dishwasher is working! Thanks.
6/20/2011 12:29:11 PM • LG LDF9810ST... • Answered on Jun 20, 2011
Lower arm does't spray model 8812
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
4/23/2011 9:19:14 PM • LG LDF9810ST... • Answered on Apr 23, 2011
2answers
I have a new (4
I would first check on your warranty before you open the unit up and void the warranty,then if you decide to open it anyway,find the tech diagnostic sheet located with-in the unit and run the diagnostics on the unit if this shows no codes then,power it down at the circuit breaker for 10 minutes and then re-power it up and check to see if this cleared the "glitch", then remove and reinstall any and all connectors and connections possible as moist air can disrupt signals from the control panel throughout the unit,if this doesn't help solve the problem,then you will need to replace the interface users control panel assy.
4/22/2011 8:11:15 PM • LG LDF9810ST... • Answered on Apr 22, 2011
0answers
Not cleaning as well as is once did.
heatman101
3/27/2011 6:54:11 PM • LG LDF9810ST... • Answered on Mar 27, 2011
2answers
I HAVE AN LG 9810ST DISHWASHER THAT HAS A WHITE
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
3/1/2011 4:25:12 PM • LG LDF9810ST... • Answered on Mar 01, 2011
2answers
In our two year old
The hinge cables have broke on your door....they connect to springs and keep the door from dropping hard....
here is the part
you will need one for each side...
heatman101
12/24/2010 8:35:41 PM • LG LDF9810ST... • Answered on Dec 24, 2010
I have a LDF9810ST that
Hey Glenn. Did you ever figure it out? I am about to replace my mother's hose since it cracked and I am looking at the service manual -but am I little stumped. I don't have the dishwasher in front of me with the part so I can't explore the options.
Also, where did you buy your part? Looks like Repair Clinic is one of the few places to have it in stock. $36.. ouch!!!
Tried to replace it with a universal model from Home Depot and it doesn't fit. Seems the LG uses a smaller outlet on the pump than others AND they have engineered a one way valve in the hose instead of the pump..
I have the same model and am just waiting for the fun to begin on mine too.
I will guarantee you that I will NEVER purchase another LG appliance again. Between non standard parts and crappy reliability, it's been a very poor customer experience to date.
12/20/2010 4:51:29 PM • LG LDF9810ST... • Answered on Dec 20, 2010
I have a LG 4821st
This code is for a "leak" that the system's computer is detecting. Let me guess...Does the system make a groaning noise like it's not getting enough water? Here's what you should do...First, pull the lower dish rack out and thoroughly clean the filter. If you're easily able to remove the filter, do so and continue to clean. Also look for any debris under the filter assembly. A final step to completely make sure all of the water lines are clear of debris, you'll need to remove power, pull the washer out of the cabinet, and then (carefully) tip it on its right side. Next, remove the two plastic assemblies that are on the left side and remove them from the dishwasher you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. It's a bit of a task, but not too difficult. To minimize this from happening in the not-too-distant future, you may want to ensure that you're not putting too many dishes in that contain heavy, solid food debris. Also, I recommend using the Finish brand tablets instead of heavy liquid detergent. It not only is more cost-effective, it also does a wonderful job and won't build up in the water lines of your nice dishwasher.
I hope this helps and please feel free to ask me if you need any further assistance!
Take care and have a WONDERFUL holiday season!
-Jason
12/14/2010 6:14:24 PM • LG LDF9810ST... • Answered on Dec 14, 2010
There is a 'Cr' message on the display panel, and
Mine is doing the same thing right now. It started beeping again this morning after I wiped off the touch pad. I shut the power off to it at the box and when I turned it back on to try to make it work it just showed the Cr on the display.
12/9/2010 12:45:59 AM • LG LDF9810ST... • Answered on Dec 09, 2010
OK, so if the dishes are not getting cleaned,
Is the water around 130 F, if so make sure you run the water at your sink till the line fills with hot water before starting the machine. Make sure your getting enough water and that the spray arms are turning and clean.
11/22/2010 5:09:16 AM • LG LDF9810ST... • Answered on Nov 22, 2010
Water leaking from exhaust
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
uyuihvx
9/29/2010 8:50:44 PM • LG LDF9810ST... • Answered on Sep 29, 2010
LG LDF9810ST Built-in Dishwasher Logo
36 questions posted
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
LG Dishwashers
  • LG Dishwashers
Most Popular Question
in our two year old
  • Dishwashers
