20 Most Recent TruTech T650-DR DVD Recorder Questions & Answers
0answers
3answers
The recorder's screen is blank
You have developed a power supply problem, to do with the electronics circuitry, the motors supply, is separate. There are no user serviceable parts inside, to even have a shot, you would need a service and repair manual, I have searched, but there is nothing available. You need to get the unit looked at by a TruTech service center,and ask for a "Quote" this way you can decide to repair or replace.
5/22/2010 1:54:29 AM • TruTech T650-DR... • Answered on May 22, 2010
Need new remote
Here are a couple of links to review....
Option 1
Option 2
Good Luck and please rate this solution...
1/9/2010 11:42:05 PM • TruTech T650-DR... • Answered on Jan 09, 2010
I have tried to load 5 different recordable discs
See if changing recording speed would help. As far as I know the discs should work. Try the discs that you have burned before on another player just to check if there is something wrong with the player.
10/5/2009 10:10:23 PM • TruTech T650-DR... • Answered on Oct 05, 2009
I accidentaly set my dvd
I think Progressive mode is selected/ activated and causing no video out to your TV, that needs to be deactivated.
Press STOP key on DVD Recorder for 6 seconds to turn progressive Off.
Let me know exact model and brand if problem still unsolved.
Thanks.
7/27/2009 12:06:21 AM • TruTech T650-DR... • Answered on Jul 27, 2009
2answers
How do I record TV
Step 1. Set the recording timer on your DVD recorder to record the chosen program when it comes on, or wait for the show to start and do the recording manually. Place a blank, recordable disc in the tray of your DVD recorder and close the tray.
Step 2. Make notes of where you'd like to insert chapter stops, being ready to skip over commercials and edit them from the program. It helps to have a general idea in advance where to insert chapter breaks. For an hour-long program, chapter breaks every 10 to 15 minutes are convenient when reviewing the program later.
Step 3. Press the "Record" button on the DVD recorder to commence burning the program to DVD. Use the Pause and Edit controls of the DVD recorder to eliminate commercials and create chapter stops on the DVD for easy browsing later. Place the recorded disc in a protective sleeve or case and label it for easy identification later.
Good Luck!!
Thanks
7/18/2009 6:07:27 AM • TruTech T650-DR... • Answered on Jul 18, 2009
I accidentaly set my dvd recorder to PAL and now
connect the green cable on your tv for get picture without color but you can see the menu to make the changes you need to do good luck
7/7/2009 12:42:37 AM • TruTech T650-DR... • Answered on Jul 07, 2009
Some dvd's will not read
you just need to clean the lens with cotton or a soft cotton cloth to avoid scratching it..be careful not to touch it with bare hands..
7/5/2009 4:57:00 AM • TruTech T650-DR... • Answered on Jul 05, 2009
Auto Tuning Problem
Wow sounds like you got a bad box,
Frist your Trutech needs to be set to Ch 3 or 4 what ever is open. if you dont see a Trutech Logo on your TV, then you need to go back to your TV and find the input Ch to your Trutech T650-DR.
If you do see the Trutech Logo then next on your Trutech T650-DR remote keep pressing the source button tell you see A Cable Ch. then press the return button.
Thats It hope I could help.
6/30/2009 3:25:17 AM • TruTech T650-DR... • Answered on Jun 30, 2009
I need the 3-digit setup Code for Trutech T650-DR DVD
Note: In order for you to watch your TV your TruTech T650-DR must be on. Not shure what you mean by code? but setup go,s like this.
Out DISHNET to in on your Trutech T650-DR
Out TruTech T650-DR to in TV Note: the name of the input on your TV video 1 or video 2.
Just like your DISHNET you need to be on Ch 3 or 4 what ever is open.
turn on your DISHNET and your Trutech T650-DR Do you see a Trutech logo on your TV?
If yes, Keep pressing the source Button on your Trutech T650-DR remote Tell you have a TV Ch. then press the return button.
use your DISHNET remote to watch your tv.
thats it hope I could help.
6/30/2009 3:11:30 AM • TruTech T650-DR... • Answered on Jun 30, 2009
Audio static through DVD Recorder
I your TruTech T650-DR is geting real hot turn it off its over heating.
If thats the case then your not setup right. What ever is gonig on dont keep using it, its gonig to burn out. cheek to make shure you have every thing plug in right.
6/30/2009 2:40:55 AM • TruTech T650-DR... • Answered on Jun 30, 2009
2answers
Trutech dvd-r
Set it for antenna and use the single channel it sends to your TV, which is the only signal coming out of your cable box
6/30/2009 2:28:38 AM • TruTech T650-DR... • Answered on Jun 30, 2009
How to burn a dvd from a JVC Hard disk drive recorder
Make sure you plug your camcorder into the in on the dvd recorder. Make sure the dvd recorder is set to that input. you may need to hook it up to a tv and make sure you see your camera on the tv going through the dvd recorded to make sure you have it on the right setting. Make sure you camera has playback out turned on.
4/14/2009 7:50:13 PM • TruTech T650-DR... • Answered on Apr 14, 2009
4answers
Trutech DVD/CD Player T600-D
We had to send ours back.
8/27/2008 10:29:26 PM • TruTech T650-DR... • Answered on Aug 27, 2008
2answers
Lost remote
Searching online I found a web site that you may order a replacement remote, however this web site no longer carries the T650-DR remote but they do carry a substitute.
http://remotes.com/remotes/servlet/rs?a=gmi&uuid=A12145901412461&smodel=T650DR&brand_pn=TRUTECH_T650DR
if the link does not work, go to http://remotes.com and in the top left search for T650-DR to find the replacement. Hope this helps, post back.
6/27/2008 6:18:31 PM • TruTech T650-DR... • Answered on Jun 27, 2008
Will This DVD Recorder Burn DVDs from a Desktop?
Ive never seen a standalone DVD recorder that can connect to a pc unless it had a Hard Drive. This model is a Target exclusive company. These devices are designed to record video direct from either Antenna,Cable,VCR,or something such as a game console, or camcorder.
Hope this helps!
5/1/2008 10:19:57 PM • TruTech T650-DR... • Answered on May 01, 2008
2answers
Can't find source
The very same problem i am having, If you find out please e-mail me @ [email protected] In subject please type DVD PLAYER..Thank you for your help
4/14/2008 11:12:49 AM • TruTech T650-DR... • Answered on Apr 14, 2008
HELP
There should be no problem with copying home recorded VHS tapes to DVD via the Scart or Video (yellow) output. It may be obvious but have you tried recording directly from other sources such as TV etc. Apologies if this is a trivial suggestion!
Cheers
4/4/2008 2:57:10 PM • TruTech T650-DR... • Answered on Apr 04, 2008
TruTech T650-DR DVD Recorder Logo
27 questions posted
Top TruTech Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
ExpressFiX
ExpressFiX
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • TruTech Televison & Video
Most Popular Question
auto tuning problem
  • Televison & Video
