20 Most Recent
LG DP781 Portable DVD Player Questions & Answers
I plugged in my usb
The size of the usb device also matters on these dvd players more often than not. If you are using a larger usb device and you have a smaller one try using it with a couple of files and see if that makes a difference.
11/6/2019 2:06:00 AM •
LG DP781...
Answered
on Nov 06, 2019
Hi
I have a portable LG
Litium battery in this portable DVD player already in the unit like the last 2 years?Yes.The litium battery require replacement.Tries websites like Partstore.com,Ebay.com,Amazon.com to buy a new litium battery for the replacement.
2/11/2016 6:06:56 PM •
LG DP781...
Answered
on Feb 11, 2016
Where can I find a
Hi susan to be sincre you can't find any battery that will last you as original one. I will suggest you offer for sale and get a new one. From deborah.
1/21/2011 12:21:36 AM •
LG DP781...
Answered
on Jan 21, 2011
Lg dp 781 is saying no cd when there is a cd in it
Look closely, with lots if light and magnifying glass, at the pickup lense. Static attracts teeny tiny fibers and they bend the light and cause read errors. Also, smoking covers lense sometimes. Can be cleaned with rubbing alcohol and swab. I think that cd cleaning disks cannot actually clean as the lense is recessed.
1/2/2011 7:04:32 PM •
LG DP781...
Answered
on Jan 02, 2011
No power
DC output voltage problem
7/3/2010 10:14:49 AM •
LG DP781...
Answered
on Jul 03, 2010
Disk error
yu need lens/laser assembly checked/replaced.
4/3/2010 7:20:03 PM •
LG DP781...
Answered
on Apr 03, 2010
LG DP781 DVD player
Souds like a cable problem. First, make sure that the cable you are using is the right cable-it should be a multi-signal cable. Look for a colored circle of insulation on the metal end that separates the tip of the connector from the bottom of it. You might even have more than two sections if it is a stereo jack. If you are sure you have the right jack/cable, then it's possible the wire carrying the video signal could be damaged. If it's not a cable issue, it's a jack issue, so look for damage on the device's output jack.
4/2/2010 1:46:42 AM •
LG DP781...
Answered
on Apr 02, 2010
How do I get a replacement av cable that works for
The length of the pin is about 1" long on the end. This is proprietary, so U have to order from the manufacturer. Radio Shacks is too short on the pin in the end as this xtra long pin is not standard. I ordered from MFR.
2/2/2010 1:51:40 PM •
LG DP781...
Answered
on Feb 02, 2010
