20 Most Recent LG 37LC5DC 37 in. LCD Television Questions & Answers
2answers
Picture sides cut off when watching avi files
My new LG LCD is not syncing the video and audio when playing avi movies on either USB stick or HDD.
11/6/2019 2:41:40 AM • LG 37LC5DC 37... • Answered on Nov 06, 2019
LG lcd tv has sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board..
7/27/2017 1:43:10 PM • LG 37LC5DC 37... • Answered on Jul 27, 2017
When power on, picture does not come on. repeat 3
It can be T-CON, MAIN, POWER supply, Inverter boards.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board. if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having. If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on: Please see my basic troubleshooting guide here: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Please post back what you find.
10/23/2010 12:59:13 AM • LG 37LC5DC 37... • Answered on Oct 23, 2010
37LC5DC
It should reset the TV or the video box back to factory settings. There is also another reset in the menu listings.
11/1/2009 8:15:14 PM • LG 37LC5DC 37... • Answered on Nov 01, 2009
3answers
Fuse diagram for a LG plasma model pdp42v80201
The screen blank out
4/7/2024 11:03:07 PM • LG Televison &... • Answered on Apr 07, 2024
LG Plasma TV is not displaying picture when it is turned on
This is the Power Board for it. check those 6 electrolytic Capacitors on the right for bulging or splitting. Don't buy it blindly, it's a guess. The output voltages with a digital multimeter. https://applianceparts.com/item/10217204/LG/EAY62812602/ Many parts are obsolete. eBay has used boards, but they are risky because they are out of scrapped sets. https://www.google.com/search?q=50PN5300-UF+power+board We have a television expert named Larry, but I haven't seen him for a while. This used to be my advice https://www.fixya.com/support/r29790007-repairing_own_television ..
3/30/2024 8:59:29 PM • LG Televison &... • Answered on Mar 30, 2024
3answers
DVD reading problem on a LG DVD5083 DVD player.
Maybe the disk is not compatible with the DVD player version
3/24/2024 9:16:41 AM • LG Televison &... • Answered on Mar 24, 2024
How do I program my DVD video remote control to my LG Blu Ray surround sound player please?
It can't be done. The DVD remote will be single frequency for that device only and the LG remote for that LG Blu Ray (or series) only. Companies don't make cross-control between makers easy. The only exception is cable and satellite boxes to allow their remote to also control the television. If you have lost a remote or it doesn't work, this is the answer https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
3/19/2024 4:25:52 PM • LG Televison &... • Answered on Mar 19, 2024
LG BD590 250 GB HD Network Blu-ray Disc Player. How to make LG BD590 region free?
Question edited for a lot more clarity. All in the link https://www.google.com/search?q=LG+BD590+make+region+free ..
3/17/2024 3:28:16 AM • LG Televison &... • Answered on Mar 17, 2024
How can I program my LG DVD remote control COV33662806 to my LG 55 Roku television.
You can't, the LG DVD Remote is single frequency. If you are lucky, the LG Television Remote, might control an LG DVD. If you have lost a remote, have a read of this https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
3/15/2024 11:09:16 PM • LG Televison &... • Answered on Mar 15, 2024
Could you help diagnose the issue with my LG TV MODEL 65UN7300AUD that does not power on?
If you would like to share any clues, yes. Checked power going in, I presume. Any indicator lights? If yes, how many times does it flash?
3/15/2024 7:15:50 AM • LG Televison &... • Answered on Mar 15, 2024
2answers
My LG DVD/CD receiver Model:LH-D6246,Shows disc 'error' when I load a dvd or cd disc but the radio plays very well please help
faulty dvd reading lens,should be change by expert professional
3/14/2024 12:44:09 AM • LG Televison &... • Answered on Mar 14, 2024
How to activate universal remote control AMELY AD-UL101S with LG TV Brand or other brand?
Question edited for clarity and add maker. No one uses Universal Remotes these day. You buy a Remote that is a Copy of the original. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote The AMELY is a very cheap and nasty Chinese Remote and they don't supply instructions!! https://www.amely.cn/AD-UL101-S-AMELY-unviersal-TV-LCD-LED-remote-control-p636185.html Codes are decided by the brand of television. This is for LG https://www.google.com/search?q=universal+remote+codes+for+lg+tv ..
3/3/2024 4:57:30 PM • LG Televison &... • Answered on Mar 03, 2024
LG DVD Player - DSI-8555 manual please?
It appears to be a model made for the India market. https://www.google.com/search?q=lg+dsi+8555+manual This is the only service manual that is related. If the display is not working, look on the back of the display board for a split or bulging electrolytic capacitor.
SERVICE MANUAL
Encompass Parts https://research.encompass.com > ZEN PDF This manual was prepared for use only by properly trained audio-video service technicians. When servicing this product, under no circumstances should the ... 109 pages
3/2/2024 7:45:46 PM • LG Televison &... • Answered on Mar 02, 2024
LG 37LC5DC 37 in. LCD Television Logo
14 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
picture sides cut off when watching avi
  • Televison & Video
